Front axle/wheel vibration after seal replaced
Hi all. I just had a local shop replace the right front axle seal(it was leaking on the exhaust...). I picked the car up, got a mile down the road and had terrible vibration and thunking in the right front. Returned to shop which was already closed for the evening(nice of him to test drive his work- huh?)
Any ideas on what the tech forgot to tighten or what he may have damaged while replacing the seal? Thanks.
While you're checking the lugnuts, check the castle nut for tightness too. Hopefully your mechanic didn't over-extend the axle and ruin the inner joint (DOJ). Does the vibration occur while accelerating and go away immediately when you let off the gas? That's a classic symptom for a bad DOJ. Check the DOJ boots also; if one is torn, the DOJ is likely bad.
