bearbalu Posted December 31, 2004 Share Posted December 31, 2004 I am getting cylinder 2 misfire. Subaru service manual seems to indicate that 1/3 and 2/4 have same resistance. Looking at spark plug wires 1/3 seem like same wire (label says 1-3) but 2 and 4 seem different (labeled 2 and 4 respectively). Can I swap them just for test? If not, is there a simple test short of buying new wires. Link to comment Share on other sites More sharing options...
cookie Posted December 31, 2004 Share Posted December 31, 2004 do when you don't have spares. If the skipping cyl changes you've hit paydirt. Link to comment Share on other sites More sharing options...
Nug Posted December 31, 2004 Share Posted December 31, 2004 Perfectly acceptable method. Link to comment Share on other sites More sharing options...
bearbalu Posted January 2, 2005 Author Share Posted January 2, 2005 Thanks folks. I tried it - seems like perfectly acceptable method. Cylinder 2 misfire didn't move to cylinder 4, so I know it it'sn't the wires. Cylinder 2 misfire however seems to have vanished mysteriously. See http://www.ultimatesubaru.org/forum/showthread.php?t=27635 if you have any interest! Link to comment Share on other sites More sharing options...
cookie Posted January 2, 2005 Share Posted January 2, 2005 Good luck Bear. Link to comment Share on other sites More sharing options...
northguy Posted January 2, 2005 Share Posted January 2, 2005 Best fix of all - one that costs nothing! Link to comment Share on other sites More sharing options...
bearbalu Posted January 3, 2005 Author Share Posted January 3, 2005 One thing I have learn from reading on this forum is that blind "replace and pray" usually leads to expensive repairs, specially CEL. Same applies for overheating - I suspect I ended up doing head gasket job because I diagnosed the problem to thermostat, it was probably a clogged radiator. Repeated overheating lead to blown head gasket. Here are a few things to try when one gets a CEL with cylinder misfire: 1. Swap spark plugs/spark plug wires/injector to see if the problem moves to another cylinder - if it does, you know what exactly to replace! 2. Measure the resistance of ignition coil/spark plug wires, injector connector against specs, before assuming they are bad 3. Listen to click-click of injectors to see if they are working okay. Link to comment Share on other sites More sharing options...
