My suggestion is to start with normal tune up maitenance. Replace plugs and wires, and see if that helps. Their cheap parts and a cheap fix, if it works. There are other questions in this forum about similar problems; try searching for those and read through them, you'll be surprised about a common problem that sounds similar to yours, but no one has found a fix....yet.
