oilserver Posted January 2, 2005 Share Posted January 2, 2005 can anyone help my gtb 95 model as a bad misfire at two and a half thousand revs and again at 4 thousand but only under heavy accelleration if i ease the throttle in its ok Link to comment Share on other sites More sharing options...
93leg Posted January 10, 2005 Share Posted January 10, 2005 My suggestion is to start with normal tune up maitenance. Replace plugs and wires, and see if that helps. Their cheap parts and a cheap fix, if it works. There are other questions in this forum about similar problems; try searching for those and read through them, you'll be surprised about a common problem that sounds similar to yours, but no one has found a fix....yet. Link to comment Share on other sites More sharing options...
Cougar Posted January 10, 2005 Share Posted January 10, 2005 Along with the ignition parts I would also do a compression check to see how things are with the cylinders. There may be an intake manifold leak also. Link to comment Share on other sites More sharing options...
