suberdave Posted January 5, 2005 Share Posted January 5, 2005 ok i have a 1988 GL EA82T FTAWD, i just did an engine swap on it, my question is the distributor i had in it was out of a 5sp car and the engine is out of an auto, i put the auto dist. in. is there a differenc between a manual and an auto dist? are they curved different or anything? Link to comment Share on other sites More sharing options...
BobBrumby Posted January 5, 2005 Share Posted January 5, 2005 nah i think the only differnece between the disty curves is between 4x4 and FWD, the fwd is ment to have a better curve but this has been refuted by many members. Link to comment Share on other sites More sharing options...
Skip Posted January 5, 2005 Share Posted January 5, 2005 Dave the distributors in the EA82T of your vintage are called crank angle sensors. 5sp and automatics are the same. All timing is handled by the ECU after the initial or static timing is set. i.e. no advance - mech. or vac. Link to comment Share on other sites More sharing options...
suberdave Posted January 5, 2005 Author Share Posted January 5, 2005 Thanks Link to comment Share on other sites More sharing options...
tizzle Posted January 6, 2005 Share Posted January 6, 2005 Suberdaqve. I just swaped an engine from an jdm auto into my 5 speed , and the distributor was different. It had a bunch of extra wires coming off it. So I just used my old distributor Link to comment Share on other sites More sharing options...
RallyKeith Posted January 6, 2005 Share Posted January 6, 2005 Dave the distributors in the EA82T of your vintage are called crank angle sensors. 5sp and manuals are the same. All timing is handled by the ECU after the initial or static timing is set. i.e. no advance - mech. or vac. Yup, I'll second that. Pre 88 they still used vaccum advance, after that it's done by the ECU. So your distributor should have no vaccum connection on it. Keith Link to comment Share on other sites More sharing options...
