So i got...
whats the honeycomb project?
this:
dude..i think i have the solution for you.
From what i remember you are running that "greddy" mushroom style air filter.....correct???
if so...your problem is this. The air entering the Air Flow meter is too turbulant. The air needs to be nice and straight when it enters the air flow meter, or else the computer will get wonky readings.
You need some way to straigthen the air flow.
What we did. Go to Mc. Donalds, and steal a handfull of drinking straws. Cut the straws into like 1 inch pieces, and make a "honeycombe". Tape them all together, and some how install them infront of the Air Flow meter....I'm not sure how your filter adapter works. but you can usually put them in the filter adapter. Once you have your "honeycombe" and have it packed into the air filter adapter, Go get some Bugscreen for screen doors. Cut a piece and stretch it over the straws and around your entire air filter adapter, so when you put your filter on, it holds the bugscreen in place.
Should make a difference.
A quick way to check...throw the stock airbox back on and see if it does it.
from this thread:
http://www.ultimatesubaru.org/forum/showthread.php?t=27443&highlight=straws
