wazza01 Posted January 7, 2005 Share Posted January 7, 2005 Subaru '81 , turn engine on no worries , turn engine off keeps running. Any suggestions other than take it to an auto electrician? Thinking install kill switch? Link to comment Share on other sites More sharing options...
MilesFox Posted January 7, 2005 Share Posted January 7, 2005 try checking for burnt wires that may be shorting out in the ign circuit, around the coil also check the pink clip near the passenger strut tower if there is still volts to the coil it will run with the key off. if you want to fix this problem cheap put a switch between the + coil terminal and its power lead Link to comment Share on other sites More sharing options...
wazza01 Posted January 7, 2005 Author Share Posted January 7, 2005 Thanks Miles , will check it out try checking for burnt wires that may be shorting out in the ign circuit, around the coil also check the pink clip near the passenger strut tower if there is still volts to the coil it will run with the key off. if you want to fix this problem cheap put a switch between the + coil terminal and its power lead Link to comment Share on other sites More sharing options...
