Tycho Posted January 8, 2005 Share Posted January 8, 2005 Hoping to fend of some detonation and keep the rings a bit more square in the bores. Link to comment Share on other sites More sharing options...
Myxalplyx Posted January 8, 2005 Share Posted January 8, 2005 Ok, I'm looking at EA82 Pistons and where the rings belong. You are looking to fend off detonation by having carefully prepped pistons. What am I looking at vs what? I'm lost! Link to comment Share on other sites More sharing options...
Tycho Posted January 8, 2005 Author Share Posted January 8, 2005 Radiused valve reliefs Thermal barrier coated dome to spread piston heat distribution (and chamber heat distribution...perhaps less cracking). This bugger seemed knock prone to begin with...and I took .010 off the block to bring piston->head to a minimum (more effective quench, better burn)...but I was concerned about the additional heat in an already borderline combination. Moly coated skirts to tighten up piston->wall clearance after honing to reduce piston rock (scuffing wasn't bad when I took it apart...but it was not as good as the EG33 i went into). They also "hold" oil to reduce (in my experience totally eliminate) damage from cold starts. I'm looking for a zero leakdown 200k miles out of this. Just an inexpensive step that makes things better. Link to comment Share on other sites More sharing options...
Subi81 Posted January 8, 2005 Share Posted January 8, 2005 Very Nice I am sure those will do great! Look what I put back into mine and it actually ran, albeit I cleaned them up a bit. But life got in the way and all I gave them was a little bit of sanding and slapped them in there. Curious how much did it cost to rework the pistons Awsome!!! Kicking myself for not spending more time. These are in the 86 wagon in the sig Link to comment Share on other sites More sharing options...
