WJM Posted January 11, 2005 Share Posted January 11, 2005 So...since I will have a full shop setup at my disposal...with a lift...should I drop the tranny, or pull the engine? Link to comment Share on other sites More sharing options...
archemitis Posted January 11, 2005 Share Posted January 11, 2005 engine. no doubt in my mind. thats what im doin tomorrow nite apparently =/ Link to comment Share on other sites More sharing options...
GLCraig Posted January 11, 2005 Share Posted January 11, 2005 If you have a lift and transmission jack, drop the transmission. Should take less then an hour. Link to comment Share on other sites More sharing options...
calebz Posted January 11, 2005 Share Posted January 11, 2005 If you have a lift and transmission jack, drop the transmission. Should take less then an hour. Yup^^ For normal people in their garages, I always recommend pulling the motor.. But if you have a lift and a tranny jack, just pull the trans. Faster and easier. Link to comment Share on other sites More sharing options...
ShawnW Posted January 11, 2005 Share Posted January 11, 2005 Depends on if the engine or tranny need servicing but I agree the easier pull is the trans if you have the lift. Link to comment Share on other sites More sharing options...
WJM Posted January 11, 2005 Author Share Posted January 11, 2005 that and i need to replace some bushings in the shift linkages anyhow....tranny it is then. Link to comment Share on other sites More sharing options...
