I recently purchased a '96 Outback Wagon (5mt, EJ22, 114K) for my daughter to commute to college. Having owned two 4wd GL wagons back in the 80's and 90's, I knew the advantage of having a reliable car that gets good gas mileage and can safely navigate the Utah winters. Compared to those slow and sturdy GL's, this OB is a rocket ship! But there were several things that needed attention, so I joined this board and got the necessary information to:
- cure the CEL and idle fluctuations by replacing the knock sensor and
the ECU's coolant temp sensor (it idles perfectly now and no CEL);
- fix the cruise by installing the $4 plastic insert in the clutch pedal arm;
- shine up the heat-hazed outer plastic on the headlamp assemblys with
some brake fluid; and
- buy the little bulbs from Radio Shack to tackle replacing the burned out
climate control lamps.
I can't say I look forward to the next issue that will pop up, but having this board as a resource will sure make whatever it a lot more bearable. You folks have saved me a lot of time, money and aggravation, so please accept my heart-felt "Thanks!"
John
