subarubrat Posted January 15, 2005 Share Posted January 15, 2005 Anyone know which calipers and rotors will bolt up to the EA81 hub and caliper mounting points? Clearly the EJ series rotors won't because they slip over the lugs. Any of the EA82's, do they have more pistons, larger pad area? Link to comment Share on other sites More sharing options...
Qman Posted January 15, 2005 Share Posted January 15, 2005 As far as a direct bolt up, Zero! Now, people have relocated the control arm mounting point and used EA82 front suspension/brake parts on EA81's. You get slightly bigger front brake rotors and caliper area is slightly larger as well. Link to comment Share on other sites More sharing options...
archemitis Posted January 15, 2005 Share Posted January 15, 2005 ya, i was measuring up xt6 to ea81 front calipers last nite, and it doesnt bolt up for sure. seems like it would be hard to do without the whole 5 lug swap stuff. Link to comment Share on other sites More sharing options...
subarubrat Posted January 15, 2005 Author Share Posted January 15, 2005 Which sucks because I have the 6 lug setup. I also threw out two stock WRX calipers just a month ago too. If I can find a caliper that has the same width and if at least one of the lugs mated up I would be fine with moving the second one. Link to comment Share on other sites More sharing options...
