Progress/Teasers ;) (56K - Sammich time)
calebz
  88rxsedan said:
must share suspension install secrets....
Got something like this
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33582&item=7956167873&rd=1
Rear install is pretty much bolt on.
1- remove strut
2- Remove stock srping
3- Install new spring using factory tophat
4- reassmble
5- Adjust to preference
Fronts required a little grinding on a little disc on the strut body in order for the adjustment collar to fit.
1- Remove strut
2- Remove spring
3- Grind little disc thingy down a little (took 10 minutes or so with an angle grinder)
4- Install new spring with new tophat
5- Reassemble
6- adjust to preference
Buying ebay springs is kind of a crap shoot. I don't see the exact springs I used on ebay any more.. Mine were listed for a WRX. Tex's were listed for a legacy. I believe brad is using some made for some VW. ALl 3 of us have a little different spring rates as well. I tried to find out beforehabd what mine would be, but the seller was somewhat lacking in teh engrish skills. I ended up with 350 rear and 450 front.. They are some stiff shizz.:D
The rest of what I did with the suspension is the basic 5 lug stuff.. Tex made a good parts list that can be found in a number of places on the board.
  nkx said:
how does the car ride? my friend put some el cheapo coilovers on his cavalier, and he hates the ride, its too bouncy.
not sure yet. I have a few other things to deal with before a real test drive can be had. I'm not the only one here that has these installed though. Perhaps Will or Brad can chime in about ride quality.
