stngllhm Posted January 16, 2005 Share Posted January 16, 2005 I have an 87 gl-10 wagon with a part-time 4wd that I just cracked the heads on it again. The moter i'm putting back in it is out of my 88 rx. I figured as long as i'm swapping the moter iI might as well swap in the dual range full time tranny. My questions are the trannys diffrent lenths ie am I going to have to do something different with my drive shafts and the diff lock mechanizn appers to be the same as what engaged the 4wd on my part time tranny i have so does that mean that the wiring for my push botton 4wheel drive is the same whiring i need for my diff lock. and any other info on the swap whould be helpful. Quote Link to comment Share on other sites More sharing options...
ballitch Posted January 16, 2005 Share Posted January 16, 2005 didnt the 87 GL-10 come with a dual range 5 speed? but i guess you want full time 4wd, with the option of lower range, right? ~Josh~ Quote Link to comment Share on other sites More sharing options...
stngllhm Posted January 16, 2005 Author Share Posted January 16, 2005 didnt the 87 GL-10 come with a dual range 5 speed? but i guess you want full time 4wd, with the option of lower range, right? ~Josh~ i got the tranny so i thought i might as well use it i also have a partime dual range but i would rather use the full time dual range. as far the gl-10 coming with the dual range i couldn't say all i know ismine has a single range part-time Quote Link to comment Share on other sites More sharing options...
baccaruda Posted January 16, 2005 Share Posted January 16, 2005 i've done this to my 86. i remember that some of the shift linkage hardware is particular to the RX transmission; that will be obvious enough when you have them next to each other. you can also wire the diff lock switch using the wiring for the push button 4WD on the GL10 tranny as it uses the same vacuum solenoid. sorry i don't have a wiring diagram but yes this is as easy as it sounds. and other RX parts that your wagon will like include the LSD, shocks/struts, strut rods, and sway bars. Quote Link to comment Share on other sites More sharing options...
monstaru Posted January 16, 2005 Share Posted January 16, 2005 i say go for the rx stuff,when his wagon ran right it was a blast to drive.....handled goooood. Quote Link to comment Share on other sites More sharing options...
stngllhm Posted January 16, 2005 Author Share Posted January 16, 2005 i've done this to my 86. i remember that some of the shift linkage hardware is particular to the RX transmission; that will be obvious enough when you have them next to each other. you can also wire the diff lock switch using the wiring for the push button 4WD on the GL10 tranny as it uses the same vacuum solenoid. sorry i don't have a wiring diagram but yes this is as easy as it sounds. and other RX parts that your wagon will like include the LSD, shocks/struts, strut rods, and sway bars. cool thanks those other parts will come later first i won't to get my car running again so i can stop driving my ford truck stupid pos Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted January 16, 2005 Share Posted January 16, 2005 Do the RX tranny swap. YOU'LL LOVE IT! I love my RX tranny, that low gear comes in real handy at red lights, uphill and definatly in snow/sand! -Brian Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted January 17, 2005 Share Posted January 17, 2005 mmmm I can't wait to swap in my RX tranny... but its going into an RX:D I still have that part time RX tranny down here though:) Quote Link to comment Share on other sites More sharing options...
MilesFox Posted January 17, 2005 Share Posted January 17, 2005 trashwagon 6 has a full rx driveline swap, xt6 5lug, 87gl10 wagon. the dual range shifter is the same as regular dual range, but the single range shifter is different. you can pop the shifter knob off the single range by driving out the 2 pins. on this car the old shifter hangs off the side and that is the diff lock! you can make a switch or put in an rx cover plate and make your own wiring in between. the s/r and diff lock mechanism is the same, but the plugs on the shift knob/diff lock switch are different as far as driveshafts use your current one. same for clutch/flywheel/pp. since its turbo the axles will fit the same, 25 spline. the plugs on the tranny itself may be different though. when you engage the diff lock the 4wd lite comes on. you will have to be inventive to make indicator for lo-range. the switch is on the lever itself Quote Link to comment Share on other sites More sharing options...
stngllhm Posted January 17, 2005 Author Share Posted January 17, 2005 well i got the engine and tranny in took all night but i love the tranny.it handles so much diffrent then what i am used to. i still need to wire the diff lock switch though but at least i have my car back. hip hip hurray Quote Link to comment Share on other sites More sharing options...
RavenTBK Posted January 17, 2005 Share Posted January 17, 2005 Hmm.. to expand my knowledge of the subject, as I read this, I'm getting the feeling that with the exception of the vacuum operated diff lock, the FT D/R RX tranny is exactly the same as the PT D/R in the other EA models correct? The RX is a very elusive breed down in these parts, and I havent found one that I can peek up its skirt just yet. Does it have an open locking center diff, or is it a locking clutch type LSD? I know its not really on topic per se.. but it doe have to do with the swap/differences between the two trannies. Please enlighten me. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted January 18, 2005 Share Posted January 18, 2005 Almost positive the Center is Open/Locked. Not LSD/Locked. The low range of the RX isnt as low as the standard 5spd D/R tranny. -Brian Quote Link to comment Share on other sites More sharing options...
stngllhm Posted January 22, 2005 Author Share Posted January 22, 2005 well now that it is all together i love it but i have noticed a big drop fuel milage and was wondering if anyone else who has swaped a full-time all wheel drive has seen fuel milage drop mine went from about 16mpg to 11mpg and yes i do have a lead foot Quote Link to comment Share on other sites More sharing options...
