WW-N-H Posted January 17, 2005 Share Posted January 17, 2005 I have owned many new vehicles but none with turbo. Now the oil leval in most when new is slightly over full. The new Legacy GT is way over the notch. Is this normal for Subaru? Also Do most use 10-30 ? Does everybody run 35psi fro and 32 re for the Potenza's ? Later Jeff Link to comment Share on other sites More sharing options...
powderhound Posted January 17, 2005 Share Posted January 17, 2005 I haven't looked at an 05 dipstick but I assume it is the same as they have always been. If you check the oil when it is hot it should be above the notch. There is a hole to indicate the proper level when hot. I like 5W-30 Mobil 1. Tire pressure?--whatever you like. Link to comment Share on other sites More sharing options...
WW-N-H Posted January 17, 2005 Author Share Posted January 17, 2005 Thanks. I am talking at least one inch high when cold. It has 300 miles and am just going to change the oil. I will use synthetic after 7000 miles. Link to comment Share on other sites More sharing options...
carlsturm Posted January 17, 2005 Share Posted January 17, 2005 Engine oil right? Not ATF? Thanks. I am talking at least one inch high when cold. It has 300 miles and am just going to change the oil. I will use synthetic after 7000 miles. Link to comment Share on other sites More sharing options...
WW-N-H Posted January 17, 2005 Author Share Posted January 17, 2005 Engine oil right? Not ATF? Yes the GT is manual not AT, Tranny. The car is my Wife's and she has not owned an Auto tranny. Last vehicle was a Wrangler. Link to comment Share on other sites More sharing options...
Setright Posted January 17, 2005 Share Posted January 17, 2005 Run it for another 300 miles and make the switch to synthetic and add a little less than the owner's manual says. Don't forget to replace the oil filter too, and fill the new filter with as much oil as it will swallow before screwing it on. (This will speed up the oil delivery on the first start after the drain.) Drive, leave level overnight, and top off if necessary. (I prefer Mobil 1, but Castrol is also perfectly respectable. I had a BAD experience trying Redline. My car developed the infamous piston slap after running Redline for less than 100 miles. Switching back to Mobil 1 5W-50 could not cure it. DANG IT!) Link to comment Share on other sites More sharing options...
WW-N-H Posted January 17, 2005 Author Share Posted January 17, 2005 So you dont have to leave the rings seat for a few more miles like in the 6 litre chevy's ? In the past I have always at least 5 thou miles then went syn. But These engines dont know. Thanks for the info. Run it for another 300 miles and make the switch to synthetic and add a little less than the owner's manual says. Don't forget to replace the oil filter too, and fill the new filter with as much oil as it will swallow before screwing it on. (This will speed up the oil delivery on the first start after the drain.) Drive, leave level overnight, and top off if necessary. (I prefer Mobil 1, but Castrol is also perfectly respectable. I had a BAD experience trying Redline. My car developed the infamous piston slap after running Redline for less than 100 miles. Switching back to Mobil 1 5W-50 could not cure it. DANG IT!) Link to comment Share on other sites More sharing options...
Setright Posted January 17, 2005 Share Posted January 17, 2005 600 miles will be enough. Most of the seating/wearing in actually happens within the first few hundred revolutions of the engine.Enjoy your Sube :-) Link to comment Share on other sites More sharing options...
Greg Posted January 18, 2005 Share Posted January 18, 2005 Hi, I changed to Mobil 1 in my 2005 Baja turbo at 3000 miles but the rings didn't seat. I was losing a little oil, (1/2 quart) So I had to use regular oil untill 10k to seat my rings. I don't know why it took so long for the rings to seat. So just keep an eye on your oil level and you should be fine. Greg... Link to comment Share on other sites More sharing options...
Subie Gal Posted January 18, 2005 Share Posted January 18, 2005 I have owned many new vehicles but none with turbo. Now the oil leval in most when new is slightly over full. The new Legacy GT is way over the notch. Is this normal for Subaru? are you checking the oil level with the engine cold? Jamie Link to comment Share on other sites More sharing options...
Greg Posted January 18, 2005 Share Posted January 18, 2005 Hi Subi Girl, Yes with engine cold. It is strange though. One time I checked the oil cold and it didn't even register on the stick. I just about freaked out, but I added an 1/2 quart and it registered almost full immediatly after that. So it seems the oil can get trapped up in the engine somewhere? How and why? Thanks greg... Link to comment Share on other sites More sharing options...
WW-N-H Posted January 18, 2005 Author Share Posted January 18, 2005 Well Gregg Here in North Dakota The Germans[and all intelligent enough to live here] are smart enough to know when and how to check the oil. No FREAKIN OUT[aka no lsd when young] When brain thought no oil on the stick [must have been having flashbacks ]. But hey to each his own. Jeff Hi Subi Girl,Yes with engine cold. It is strange though. One time I checked the oil cold and it didn't even register on the stick. I just about freaked out, but I added an 1/2 quart and it registered almost full immediatly after that. So it seems the oil can get trapped up in the engine somewhere? How and why? Thanks greg... Link to comment Share on other sites More sharing options...
Setright Posted January 18, 2005 Share Posted January 18, 2005 Oil can hang about in the rocker covers. The car must be on perfectly level ground to ensure an accurate reading. Link to comment Share on other sites More sharing options...
Tiny Clark Posted January 18, 2005 Share Posted January 18, 2005 http://www.hastingsmfg.com/Service%20Tips/compression_ring_seating.htm I think that many, many years ago, rings were not taper faced, but straight. This would have required driving for a few thousand miles to ensure the rings would properly seat against the side of the cylinder wall. Link to comment Share on other sites More sharing options...
Greg Posted January 18, 2005 Share Posted January 18, 2005 Well Gregg Here in North Dakota The Germans[and all intelligent enough to live here] are smart enough to know when and how to check the oil. No FREAKIN OUT[aka no lsd when young] When brain thought no oil on the stick [must have been having flashbacks ]. But hey to each his own. Jeff I'm not sure, but I think I've just been insulted? Greg.. Link to comment Share on other sites More sharing options...
WW-N-H Posted January 19, 2005 Author Share Posted January 19, 2005 No Gregg I really wasnt insulting just thought you were having fun so I did also, but last night my humor from bad day was not good . Sorry if you took it serious. Jeff I'm not sure, but I think I've just been insulted? Greg.. Link to comment Share on other sites More sharing options...
Greg Posted January 19, 2005 Share Posted January 19, 2005 No Gregg I really wasnt insulting just thought you were having fun so I did also, but last night my humor from bad day was not good . Sorry if you took it serious. Jeff WWNH, Jeff. No problem. Thank you for the reply. I have never owned a Subaru before and I think I have alot to learn about the strange engine particulars. Such as the rocker covers holding oil long after the car has been shut off, giving a low oil reading. Thank you all for the help with my questions. Greg... Link to comment Share on other sites More sharing options...
