baccaruda Posted January 18, 2005 Share Posted January 18, 2005 will the waterpump from my GL10 turbowagon (PS, A/C, pulley slides over studs in the waterpump and fastens with nuts) work on a turbo XT with PS and A/C? since the pulley is in theory interchangeable... Link to comment Share on other sites More sharing options...
MilesFox Posted January 18, 2005 Share Posted January 18, 2005 use whatever pump tou want. use the pulley that goes too the shot pump 105mm has the pullet that bolts to the eater pump the long pump 110mm has the pulley that slides to studs. the only difference with xt pulleys is the flat belt grooves, but wii fit the same to a relative water pump Link to comment Share on other sites More sharing options...
baccaruda Posted January 18, 2005 Author Share Posted January 18, 2005 thanks MF Link to comment Share on other sites More sharing options...
WJM Posted January 19, 2005 Share Posted January 19, 2005 thanks MF ummm...mkay. Pretty much what Miles said....I have done this before...if you've got a pump thats not the right height, you can press or pull the hub to the right place, and the studs ARE removable to fit w/e pully you want. Link to comment Share on other sites More sharing options...
baccaruda Posted January 19, 2005 Author Share Posted January 19, 2005 shanks WJM Link to comment Share on other sites More sharing options...
