Where do these Rubber hoses go
Use the circles as a guide. I need to know where the two hoses on the bottom right-hand side of the blue circle plug into.
I also need to know where the two rubber hoses on the right side of the green circle (at 3:00 position) plug into.
Here's my situation below:
The car will almost be drivable after figuring this out. I need to fix an intake piece as well.
the green circle is the injector resistor pack. no lines shold go to that. there is a turbo managment valve behind it. that goes to the wase gate actuator I think.
the blue circle is the stupid sensor that turns on the turbo light. that line goes to a reducer then to the manifold on the right side.
the line with a curl on the end comes off the pressure side of the turbo I think.
for future line removal try painting or marking the lines color code style.
doh.. I get it. the circles are just points of referance.
well my previous statment should still help you out.
Yes, they help. Thanks!
I 'stole' the circled pics from another thread in which I took this pic and someone modified it to help me...yet again.
And I know better to label/mark rubber hoses. I just went about tearing at stuff like a moron. Oops!
