BobBrumby Posted January 19, 2005 Share Posted January 19, 2005 As the title indicates i am setting up some intermitent wipers on my brumby without them. I have the int. switch and int. module. Could anyone tell me if the same wiring loom in was used in dl or gl or was there more than one loom used in production? Cause I have the forth wire running to the wiper motor suggesting that atleast some of the wiring is in for the int. wippers. What would be ideal would be there already a plug under the dash for the module and just have to swap the switches. I have a 6 wire int. module and 6 wire int. switch. Any help/advice would be muchly appreciated. Link to comment Share on other sites More sharing options...
Ross Posted January 19, 2005 Share Posted January 19, 2005 Brumbys came out in '90 without int wipers?????? Link to comment Share on other sites More sharing options...
BobBrumby Posted January 19, 2005 Author Share Posted January 19, 2005 well in australia yeh i supose it, i dont see why the p.o. would change out the switch Link to comment Share on other sites More sharing options...
Ross Posted January 19, 2005 Share Posted January 19, 2005 Odd. I would think that the wiring would all be there somewhere - i'd say it owuld have cost fuji far more to make different wiring looms than the wiring saved would justify. Plus the fact that my 81 gl had heaps of extra wiring that never did anything - i presume for air conditioning and the likes. Link to comment Share on other sites More sharing options...
BobBrumby Posted January 19, 2005 Author Share Posted January 19, 2005 Where is the stock location for the int. wiper module I need a ball park location to start my search for its plug. Link to comment Share on other sites More sharing options...
Ross Posted January 19, 2005 Share Posted January 19, 2005 Where is the stock location for the int. wiper module I need a ball park location to start my search for its plug. Its roughly above the accelerator pedal on mine, i presume yours is the same. Take off the kick panel and its about 150-200 mm upwards. Link to comment Share on other sites More sharing options...
BobBrumby Posted January 20, 2005 Author Share Posted January 20, 2005 right next to the relay's on the bit of body right or left (for you yanks) to steering column and above accelerator? Hmmm it not very easy to compare aussie soob to an american one. Do they reverse the pedal box aswell e.g. is your accelerator on the right? Link to comment Share on other sites More sharing options...
stinky Posted January 20, 2005 Share Posted January 20, 2005 Hey Bobbrumby, The one in my wagon is located just next to the fuse box. I'm pretty sure the brumby's have the loom for it so the relay and switch just need to be plugged in. Link to comment Share on other sites More sharing options...
Ross Posted January 20, 2005 Share Posted January 20, 2005 right next to the relay's on the bit of body right or left (for you yanks) to steering column and above accelerator? Hmmm it not very easy to compare aussie soob to an american one. Do they reverse the pedal box aswell e.g. is your accelerator on the right? I'm from New zealand, we drive on left of road like you! Link to comment Share on other sites More sharing options...
