tizzle Posted January 20, 2005 Share Posted January 20, 2005 It's nocticeable in 1st through 3rd, when going a constant speed. Its sort of a jerking, surging motion. Any ideas to what this could be? A friend said there should be a valve stem to release air from the fuel lines, that might fix the problem, but I don't seem to have one of these. The car also likes to idle low and die if I don't keep on the gas a little. I thought about adjusting the idle speed, but you are supposed to disconnect the purge line, and I'm not sure which one that is. Also I adjusted my ignition timing, and I got it lined up right on the dot, but the distributor is clocked all the way to one direction, so any further adjustments are impossible. What's the deal with this? Thanks for any ideas, --Todd Link to comment Share on other sites More sharing options...
JWX Posted January 20, 2005 Share Posted January 20, 2005 umm, me thinks this is normal Link to comment Share on other sites More sharing options...
Dennis ex24 Posted January 20, 2005 Share Posted January 20, 2005 nope, but it plaugues ea82t's. i had one a while back that did this, i cant remember what caused it. i think it had something to do with the knock sensors being overly sensitive, check your timing and fill it up with premium. see what it does. Link to comment Share on other sites More sharing options...
Vanislru Posted January 20, 2005 Share Posted January 20, 2005 If it's a turbo then I'd check, vac lines, the movement of the vac advance in the disty and clean if nec., and the fuel pump. From reading similar threads and my own experiance it'll be a tired fuel pump. They do that when they are on there last legs this prob has been discussed in countless threads. Oh yeah make sure your TPS is set properly too. Link to comment Share on other sites More sharing options...
hooziewhatsit Posted January 20, 2005 Share Posted January 20, 2005 a cheap check would be to replace the fuel filter also. Link to comment Share on other sites More sharing options...
tizzle Posted January 20, 2005 Author Share Posted January 20, 2005 The thing is I don't remember the car doing this before I changed the engine. Its a pretty voilent jerking motion, that I don't want to just "live with." Its got a jdm engine now, and I've put about 70 miles on it, new seals, hoses, gaskets. I replaced the spark plugs, spark plug wires, disributor cap and rotor, water pump, oil pump, air filter. I put in an optima red top battery, switched the idle air control valve and gasket, cleaned the coolant temp sensor, and a bunch of other crap I'm forgetting I have not however done anything with the fuel pump. I can't think right now about what TPS is. --Todd Link to comment Share on other sites More sharing options...
Ross Posted January 21, 2005 Share Posted January 21, 2005 My ea81t has the same symptoms, although i wouldn't call it violent. I have found the vacuum advance diaphragm is bad, and am replacing it either today or on monday......I'll post the results! Link to comment Share on other sites More sharing options...
Vanislru Posted January 21, 2005 Share Posted January 21, 2005 tizzle said: The thing is I don't remember the car doing this before I changed the engine. Its a pretty voilent jerking motion, that I don't want to just "live with." Its got a jdm engine now, and I've put about 70 miles on it, new seals, hoses, gaskets. I replaced the spark plugs, spark plug wires, disributor cap and rotor, water pump, oil pump, air filter. I put in an optima red top battery, switched the idle air control valve and gasket, cleaned the coolant temp sensor, and a bunch of other crap I'm forgetting I have not however done anything with the fuel pump. I can't think right now about what TPS is. --Todd TPS is the throttle position sensor and it's on the throttl body , little black box 2 ph illips screws adjust as per manual. Vac advance unit on the disty goes but some times the actuator in the disty itself gets gummed up, a little cleaning[ i used brake cleaner] and oil works wonders. Can you here any leaks hissing at all when the motors running? Link to comment Share on other sites More sharing options...
Ross Posted January 22, 2005 Share Posted January 22, 2005 I repalced the vacuum advance on the ea81t, and solved my jerking prob completely. You might want to check yours, if it has one. Link to comment Share on other sites More sharing options...
Ross Posted January 23, 2005 Share Posted January 23, 2005 Maybe not, its back again! Link to comment Share on other sites More sharing options...
85Sub4WD Posted January 23, 2005 Share Posted January 23, 2005 If your disty is at the end of the adjustment, then it is probably off a tooth. Being an 88, yours should not have a vacuum advance. I think a knock sensor/tps sensor is likely. Check for error codes; if either sensor is REALLY out of whack, it will come up. Link to comment Share on other sites More sharing options...
tizzle Posted January 23, 2005 Author Share Posted January 23, 2005 Ok, haven't been able to check in often due to a fried hard drive:banghead:. But I figured out the problem. I messed with the distributor. Turns out I had done the ignition timing very wrong. I'm an idiot, and also 2 of the connections int the wires were receded into the boots. But now the ignition is all set to stats, and the RX is running very pretty. It still has a very slight jerking, but not very noticeable. I rechecked the codes, and got abnormal o2 sensor, and something about the wastegate I think, 32 and 44. anyways, thanks guys Link to comment Share on other sites More sharing options...
tizzle Posted February 22, 2005 Author Share Posted February 22, 2005 I think the surging problem is now 100% fixed, after I replaced the fuel pump. Finally, ..smooth fuel delivery is great! Link to comment Share on other sites More sharing options...
4WDFrenzy Posted February 22, 2005 Share Posted February 22, 2005 Well that is certainly good to know. I might have to do that when I return from Okinawa. Mine kinda surges a little at lower speeds(under 30mph). Good info!!! Link to comment Share on other sites More sharing options...
MilesFox Posted February 22, 2005 Share Posted February 22, 2005 the 88 rx has an optical disty, so the vac advance only applies to 85-86 models there are 2 screws that hold the throttle body in place, the holes are slotted and you can clock the mechanism one way or the other whats inside is an idle switch and a WOT switch, take off the sensor and shake it, if it rattles toss it and get another one check the idle and WOT switch per instructions in the haynes manual, chapter 6 engine emissions and controls, throttle pos sensor Link to comment Share on other sites More sharing options...
Vanislru Posted February 22, 2005 Share Posted February 22, 2005 Vanislru said: If it's a turbo then I'd check, vac lines, the movement of the vac advance in the disty and clean if nec., and the fuel pump. From reading similar threads and my own experiance it'll be a tired fuel pump. They do that when they are on there last legs this prob has been discussed in countless threads. Oh yeah make sure your TPS is set properly too. I've replaced 2 fuel pumps on my t wagons now and have replaced a friends too, I think maybe it has to so with there location, all the shaking? At least they aren't in the tank:) . Link to comment Share on other sites More sharing options...
