I misaligned my timing belt- Help!
I was fixing a leaky oil pump when I noticed that the alignment marks for my camshaft sprockets were about 45 deg. off from where I thought they should be. Since I can be immensly stupid when not fed properly, I put them where I thought they should be. I was wrong! and turned the engine over twice with the cams baout 45 deg, off. Did I bend the valves? Am I sunk?
Thanks everybody. BTW, I got into trouble by doing exactly that-lining up the marks on the camshaft sprockets to notch at the top of the cover and by aligning the small triangle-shaped mark on the crankshaft gear with the top of the crankcase seam. I did not see any other marks, although the manual download I saw shows a mark on the ring behind the crankshaft gear that the crankshaft sensor reads. I hope my suby has one.
