Bucky92 Posted January 20, 2005 Share Posted January 20, 2005 This morning I went out to do my usual warm up of Bucky and when I came back out 10 minutes later the inside of the car was loaded with smoke..smelled like burnt oil ( I just topped him off the day before and did get some on the exhaust so that smell is understandable) I am just curious why so much of it ended up INSIDE the car..comeing out the heater vents... Once again..am I over reacting or is this a common occurance or an easy fix..or what would be causing this???? Thanks to you all in advance Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted January 20, 2005 Share Posted January 20, 2005 This is just a half educated guess on my end, but I think the heater air intake is up at the back edge of the hood. As the smoke rose off the exhaust it probably floated up to this area and was therefore sucked in the heating system. Like I said, just a guess, but I think its possible Link to comment Share on other sites More sharing options...
Qman Posted January 20, 2005 Share Posted January 20, 2005 Common occurance from overheated exhaust. Usually happens if you don't kick it down off of high idle setting. If you start it and let it idle for a minute then tap the gas it should go to the second high idle setting. Our old '84 would do this if we didn't do that or let it idle too long. Link to comment Share on other sites More sharing options...
Bucky92 Posted January 20, 2005 Author Share Posted January 20, 2005 Cool thanks!!! I was thinking something similar to Flowmaster about the vents but my thought was they might be clogged cause I didnt clean the car off yet (snowed last night). And I can understand what Qman said ..I did kick him down but he was still idling at 1800 (he races at 2300 at first start-up) for between 10-15 minutes. Thanks for easing my pain:grin:. Over protective of my baby. Link to comment Share on other sites More sharing options...
Turbone Posted January 20, 2005 Share Posted January 20, 2005 Might want to check the inside DOJ of the passenger side axle. When the boot breaks they blow grease all over the exhaust. Link to comment Share on other sites More sharing options...
s'ko Posted January 20, 2005 Share Posted January 20, 2005 same thing happened to me once. Left the car idleing too long at high rev and though I fried the cat. It should be ok. Just remember to tap gas pedal after it initially warms up. BW Link to comment Share on other sites More sharing options...
Microracer Posted January 21, 2005 Share Posted January 21, 2005 Yep, same here. No smoke, just had that strange burnt smell. No problems in warmer weather, but now it's like 10 above in the mornings, so after a minute or so I tap the gas before I go back inside to warm up. Brrrrr...... Link to comment Share on other sites More sharing options...
subeman90 Posted January 21, 2005 Share Posted January 21, 2005 Maybe Bucky was just having a smoke break... Matt Link to comment Share on other sites More sharing options...
Bucky92 Posted January 21, 2005 Author Share Posted January 21, 2005 I tried something different with Buck tis-morning...and no smoke..But I couldnt get him to kick down below 1500 RPMs until I shut him off at the gas station about 20 minutes later. But it was 3 degrees! LOL Matt..he if Bucky wants a smoke break thats fine with me..I just dont want to know what he is smoking and I surely dont want him to share. Link to comment Share on other sites More sharing options...
americanyouth Posted January 21, 2005 Share Posted January 21, 2005 subeman90 said: Maybe Bucky was just having a smoke break... Matt Link to comment Share on other sites More sharing options...
