teppichkopf Posted January 21, 2005 Share Posted January 21, 2005 I have an occasional noise from the front driver side. Usually happens when colder. Sounds like the wheel is hitting the fender or such. Doesn't sound like a brake sound. CV axle less than 5000 miles. No visable defects. Can't really hear sound when window is down. More from the footwell. Doesn't stop when there is no load on the engine. Turning doesn't seem to make a difference.Revolution dependent. Faster, more thunks. Slower, less. Could it be a bearing? Link to comment Share on other sites More sharing options...
Nug Posted January 21, 2005 Share Posted January 21, 2005 It could be. I'd check to see of the axle nut was tight, and the condition of the CV boots first. Link to comment Share on other sites More sharing options...
northguy Posted January 21, 2005 Share Posted January 21, 2005 Bearings usually scream - probably a bad cv axle or doj. Link to comment Share on other sites More sharing options...
teppichkopf Posted January 21, 2005 Author Share Posted January 21, 2005 Dumb question ... what's a "doj"? northguy said: Bearings usually scream - probably a bad cv axle or doj. Link to comment Share on other sites More sharing options...
Seahag1978 Posted January 21, 2005 Share Posted January 21, 2005 They scream and then after a few miles, they sound like the whole front end is falling off! It was so loud, it totally drowned out the sound of my blown ring and pinion and leaky exhaust. Link to comment Share on other sites More sharing options...
SevenSisters Posted January 22, 2005 Share Posted January 22, 2005 Turn up the radio. I would have sworn it was tire noise until I replaced them and the noise continued. Rear bearing was the problem. Your description sounds like it could be brakes (rusty rotors) rubbing to me, but I can't hear it unless you drive past. Link to comment Share on other sites More sharing options...
Setright Posted January 22, 2005 Share Posted January 22, 2005 Bearing noise usually fluctuates with load, ie. turning. Link to comment Share on other sites More sharing options...
