shortlid Posted January 22, 2005 Share Posted January 22, 2005 Has anyone on the group found a good replacement for the SOA crush washers? I replace them everytime i chnage the oil or ATF but I don't like throwing anything more than I have to away and they ar $1.25 EACH from the local stealership!!! I found a aftermarket drain plug that came with the right size rubber gasket??? Link to comment Share on other sites More sharing options...
SevenSisters Posted January 22, 2005 Share Posted January 22, 2005 I've been reusing a copper drain plug gasket. No problems to date. I wouldn't use rubber or plastic. Heck, for what you're paying you could pay for one of those slick Fujimoto drain valves in no time. Link to comment Share on other sites More sharing options...
shortlid Posted January 22, 2005 Author Share Posted January 22, 2005 I've been reusing a copper drain plug gasket. No problems to date. I wouldn't use rubber or plastic. Heck, for what you're paying you could pay for one of those slick Fujimoto drain valves in no time. Can you get thouse Fujimoto drain valves in the right size for Roos??? Link to comment Share on other sites More sharing options...
The Dude Posted January 22, 2005 Share Posted January 22, 2005 Can you get thouse Fujimoto drain valves in the right size for Roos??? Yes, you can get a FUMUTO drain valve for Subarus. Iv'e had one in my Forester for the last five years. They are worth every penny. I highly recommend them . Link to comment Share on other sites More sharing options...
hklaine Posted January 22, 2005 Share Posted January 22, 2005 $0.55 at my dealership. I change them when I have one or its convenient. I have never had leaks though, even with repeated reuse. -Heikki Link to comment Share on other sites More sharing options...
knelson Posted January 22, 2005 Share Posted January 22, 2005 Has anyone on the group found a good replacement for the SOA crush washers? (...snip) Own two Subarus (94 Legacy, 99 Forester) and except for when I took them in for timing belt changes, have always done the oil myself. Have always just reused the old washers. No problems. No oil leaks... at least from the plug! -kurt Link to comment Share on other sites More sharing options...
shortlid Posted January 24, 2005 Author Share Posted January 24, 2005 Own two Subarus (94 Legacy, 99 Forester) and except for when I took them in for timing belt changes, have always done the oil myself. Have always just reused the old washers. No problems. No oil leaks... at least from the plug! -kurt Cool so I DON'T need to replace them EVRY time I change the oil!!! Link to comment Share on other sites More sharing options...
later, Peter Posted January 24, 2005 Share Posted January 24, 2005 They're over a buck here in Central Oregon dealership but only 60 cents in Portland (must be the freight, huh?)... for half a buck why risk it? Later, Peter Link to comment Share on other sites More sharing options...
knelson Posted January 25, 2005 Share Posted January 25, 2005 ... for half a buck why risk it? What's to risk? A little drop of oil every few miles down the road if it doesn't work? It's not like you're going to blow a gusher out. Granted, it's only like $30 over 100,000 miles (assuming you change oil every 3750 or so), but it's still $30. Guess I'm just cheap... and lucky! -kurt (You actually think the dealership changes them?) Link to comment Share on other sites More sharing options...
