97 OB headlights in a 98 Legacy L?
Thanks folks. I'm pretty sure they'll fit...the fact that it's an H4 bulb is the entire point ;-) I'm planning on some lighting upgrades.
Actually, there were two different revisions. the early revision had the headlamp assembly and the turn signal assembly as one unit. The second revision has the headlamp assembly and the turn signal assembly as two separate units. My 96 Outback has the first revision. I'm not sure about the 97, but you might want to check to see if the headlamp and the turnsignal are a separate unit or combined as a single unit.
