JonOfScio Posted August 23, 2003 Share Posted August 23, 2003 Can you put the EA81 Sub4 heads onto an EA81T and use the turbo without much trouble? thanks Link to comment Share on other sites More sharing options...
GLCraig Posted August 23, 2003 Share Posted August 23, 2003 You would have to modify the heads or intake to accept fuel injectors. Link to comment Share on other sites More sharing options...
CIS Subaru Posted August 23, 2003 Share Posted August 23, 2003 From the Sub4 website, it looks like you'd have to build a custom intake. All I saw were dual intakes for dual carbs and throttle-body injection. Hopefully, "ramperf" will respond to this because I think he sells Sub4 stuff here in the US. Link to comment Share on other sites More sharing options...
ramperf Posted August 24, 2003 Share Posted August 24, 2003 You will have to make a complete intake system but it can be done or you can send your heads to me and I can dual port them for you and build the manifold to accept your turbo, this is less money to do than just the sub4 heads. I also build new cams for this engine to take full advantage of the heads. Ron Link to comment Share on other sites More sharing options...
JonOfScio Posted August 24, 2003 Author Share Posted August 24, 2003 how much to dual port the intake and heads? dual port means a seperate port for each intake, or exhaust, or are you talking both? and how much for a 130hp grinded cam? that's how much I'm aiming for. stock EA81T is 110hp, so I figure an increase in 20hp is a good aim. Link to comment Share on other sites More sharing options...
ramperf Posted August 25, 2003 Share Posted August 25, 2003 You send your heads and the price is $995.00 to convert. This conversion is the intakes only but the exhaust is equalized and both are flowed. The intake is built for the flange of the throttle body you are using and flowed also for $555. The water provision and the injector bosses are extra. The 130hp you saw was with a single carb not turbo.On my dyno with 8lbs boost our engine produced 200hp. This engine in stock configuration will n ot hold up to this and I had to install my forged pistons,ss valves,bronze stepped guides, roller rockers, extra dowlings in the mains, etc. So turn down the boost and enjoy. Ron Link to comment Share on other sites More sharing options...
JonOfScio Posted August 25, 2003 Author Share Posted August 25, 2003 ok, so say I wanted 200hp out of my EA81T engine. What's the total cost of all parts? (minus shipping) This might be something I will want to do. Link to comment Share on other sites More sharing options...
ramperf Posted August 26, 2003 Share Posted August 26, 2003 jon, go to ramengines.com and look around. I think it would be better for you to look at a long block it will save your $ in the long run. my price for a turbo long block is $3795 Less $200 for your core if you care to trade it in. Plus the intake.I can price out all the parts for you, if you still want. Ron Link to comment Share on other sites More sharing options...
JWX Posted August 26, 2003 Share Posted August 26, 2003 how hard is it going to be to put in a n/a engine bay? Link to comment Share on other sites More sharing options...
ramperf Posted August 26, 2003 Share Posted August 26, 2003 it will go right in. have one in pilly with a weber. had to put a small turbo bubble in hood Link to comment Share on other sites More sharing options...
JWX Posted August 26, 2003 Share Posted August 26, 2003 wow, I bet it looks cool with a dimple in the hood drooll:slobber: Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted August 26, 2003 Share Posted August 26, 2003 Ramperf... did you get the message i sent you via USMB? I might need your assistance with some work I need done. Will be eager to talk to you about some head and cam work. -Brian Link to comment Share on other sites More sharing options...
ramperf Posted August 26, 2003 Share Posted August 26, 2003 sorry didn't get it or lost it. I 'll check again Ron Link to comment Share on other sites More sharing options...
