Alternators
What is the most powerful alternator I can bolt into my 91loyale wagon?
I'm currently running the stock set up and I need more power to run my cb as 1000 watts isn't enough for me. I have 2 extra batterys hooked up in the back of the car and they help a little but I need more amperage. Has any one ever hooked up duel alts in a subaru befor? Any info would be gladly appreciated. :drunk:
yeah, I never have used the ac, but that was in colorado. I haven't spent a sunner in north carolina yet! I am willing to scrap the ac if I need a second alt.
I'll look into the gm alternator. the set up I'm going for for the cb is going to hopefully put out 2000-3000watts of power when i key the mic up, and i am planing on adding two mor batterys in the back, so I,m looking for the most amperage I can possibly get out of an alt. :drunk:
Mudduck,
Have you considered the hazard of exposing yourself to that much RF energy so close? Not to mention the legality of this setup.
I'm not going to be running that kind of power all the time, just for the occational times when I need all of that and for "keydown" competitions. As far as leagality on 11 meters, no coment :D
Do a search for GM alternators. Somebody found one a while back that bolts right up after you file one of the mounting tabs a little bit which produces at least 90 or 100 amps. He found it online for less than $100.
I think I might see what gm has to offer. I might see what Leece Nevile has as far as an alt. that might fit also. I really don,t want to get to costom on the brackets, but, if it comes down to it I'll do what I got to do!
