Motor and Tranny swap
Anything is possible!
And Subarus are easy!
As far as the motor goes, I'd make sure you have the computer and black boxes out of the Hatch. You'd need to match the Fuel Pump control unit to the carb so you'd have to transfer that from the donor car.
Do a Search on the motor swap?
Good luck
Glenn
82 SubaruHummer
01 Forester
I understand the axles to be the same...
The drive lines will change depending on if it is a 4 or 5 speed tranny.
4 Speed will be one piece
5 Speed will be two...
The hatch and wagon are different length vehicles so some shortening/lenghtening may be in order.
Glenn,
82 SubaruHummer--shortened driveline. (-"15)
01 Forester--factory driveline
