tomson1355 Posted January 26, 2005 Share Posted January 26, 2005 The FSM says: Do not use a lateral type vise. Do not allow press pressure to exceed 9807N (1000Kg, 2205 Lb.) What is the reason for not using a lateral type vise? Can I use one if I'm careful? I'm sure I could be careful enough to not exceed 2205 lb. Thanks, Tom Murphy Earlville, NY Link to comment Share on other sites More sharing options...
frag Posted January 26, 2005 Share Posted January 26, 2005 Most everyone here use a standard shop vise. You only have to be sure both ends of the tensionner are at an exact 90° to each jaw and that you compress VERY slowly. Link to comment Share on other sites More sharing options...
