freedster Posted January 27, 2005 Share Posted January 27, 2005 Hello all- Sorry if this is a noob question, but I'm still learning. I was just wondering if there were any Impreza parts out there (or parts from other models for that matter) that I could bolt up to my 88 GL hatch to upgrade it. I know that with other manufacturers you can pick and choose better parts from other year or model cars and make such upgrades (like swapping to 5-lug hubs, swapping out springs or shocks, or even changing over to disk brakes) and I'm wondering if any such goodness could be in store for my little GL. Looking to improve handling and braking, mostly, though finding some power or new seats might be nice too. Thanks in advance for the info. - Freed Link to comment Share on other sites More sharing options...
dragonlee2 Posted January 27, 2005 Share Posted January 27, 2005 Actually I have close to the same question. I have an 88 GL 4wd Hatch and want to know if any rear axle parts from a 90 impreza sedan AWD will be interchangeable. My rear left bearings went out and most of the left axle needs to be replaced. Not sure on on the terminology concerning Subarus but everything from the hub to almost the drive shaft needs replacing. Link to comment Share on other sites More sharing options...
Dr. RX Posted January 27, 2005 Share Posted January 27, 2005 If you what to do a 5 bolt conversion, you'll need to ge a tranny with a 25 spline stub axle (ie and turbo tranny), then you can only use front suspension parts, the knuckle, strut, axle, tie rod end, ball joint, and all the brake stuff, but now you won't have an e-brake. Nothing in the rear will work. Dragonlee, I'd like to see that 90 Impreza, it is rare, considering that Subaru didn't make an Impreza until 1993. Link to comment Share on other sites More sharing options...
dragonlee2 Posted January 27, 2005 Share Posted January 27, 2005 Dragonlee, I'd like to see that 90 Impreza, it is rare, considering that Subaru didn't make an Impreza until 1993. Lol sorry Legacy, was looking at pictures of Imprezas. Link to comment Share on other sites More sharing options...
Dr. RX Posted January 28, 2005 Share Posted January 28, 2005 Lol sorry Legacy, was looking at pictures of Imprezas.Same answer holds true for Legacys. Link to comment Share on other sites More sharing options...
freedster Posted January 29, 2005 Author Share Posted January 29, 2005 So, were there any disc brake or 5-lug cars that I can pull 100% compatible parts from? (Like a disc brake Loyale or something like that?) I was hoping that when I do the brakes for the car, I could just buy the parts for a 5-lug and/or disc brake setup and upgrade at the same time. I never did like drum brakes all that much (except for the ones on the late 60's Buicks with those huge, gorgeous cast aluminum drums!) and if I can get them out of there, so much the better. I'm hoping to autocross this car some day. - Freed Link to comment Share on other sites More sharing options...
Dr. RX Posted January 29, 2005 Share Posted January 29, 2005 So, were there any disc brake or 5-lug cars that I can pull 100% compatible parts from? (Like a disc brake Loyale or something like that?) I was hoping that when I do the brakes for the car, I could just buy the parts for a 5-lug and/or disc brake setup and upgrade at the same time. I never did like drum brakes all that much (except for the ones on the late 60's Buicks with those huge, gorgeous cast aluminum drums!) and if I can get them out of there, so much the better. I'm hoping to autocross this car some day. - Freed If you use XT6 front calipers and the complete rear disc brakes they should bolt on. Note, it needs to be a 4WD XT6 for the rear brakes, you'll need to pull eveything from, and including, the backing plates outward. Link to comment Share on other sites More sharing options...
Turbone Posted January 29, 2005 Share Posted January 29, 2005 I'm a little confused, and a bit surprised that the good Dr. didnt ask (unless I missed something). Is this 88GL Hatch a EA81 or EA82? Does it have the small hatch or the big window hatch? The EA82 GL is usually called a 3 door. The 5 lug will work on EA82's, but its a real PIA to do it on a EA81. Rear disc's can be gotten from all EA82 turbo'ed cars, and its practically bolt on. Link to comment Share on other sites More sharing options...
Dr. RX Posted January 29, 2005 Share Posted January 29, 2005 I'm a little confused, and a bit surprised that the good Dr. didnt ask (unless I missed something). Is this 88GL Hatch a EA81 or EA82? Does it have the small hatch or the big window hatch? The EA82 GL is usually called a 3 door. The 5 lug will work on EA82's, but its a real PIA to do it on a EA81.Rear disc's can be gotten from all EA82 turbo'ed cars, and its practically bolt on. Gee Rob, I can't believe that you would challenge the doctor. Yep, the hatch is an EA81, if the rear brakes off of an EA82 will fit on an EA81 then the rear brakes off of a XT6 will fit also. As for the fronts, if you use the strut tops off the that EA81 struts, the EJ series struts will bolt right in. Or you can redrill the strut tower on the EA81 to accept the three holes required for the EJ series struts. Link to comment Share on other sites More sharing options...
bushbasher Posted January 29, 2005 Share Posted January 29, 2005 Same answer holds true for Legacys. didnt the legacy wagons start in 1990? My friends mom drives a 91 turbo 5spd sedan. Link to comment Share on other sites More sharing options...
dragonlee2 Posted January 29, 2005 Share Posted January 29, 2005 I'm a little confused, and a bit surprised that the good Dr. didnt ask (unless I missed something). Is this 88GL Hatch a EA81 or EA82? Does it have the small hatch or the big window hatch? The EA82 GL is usually called a 3 door. The 5 lug will work on EA82's, but its a real PIA to do it on a EA81.Rear disc's can be gotten from all EA82 turbo'ed cars, and its practically bolt on. Ok you asked if it had a small or big window but then didn't say which is which. My 88GL is a four door with a hatch, the window is half the hatch. So what would that make it? Link to comment Share on other sites More sharing options...
bushbasher Posted January 29, 2005 Share Posted January 29, 2005 Ok you asked if it had a small or big window but then didn't say which is which. My 88GL is a four door with a hatch, the window is half the hatch. So what would that make it? 4dr hatch? are you including the hood in this count??? does it look like this: called a "hatch" or like this: normally called a "3dr" Link to comment Share on other sites More sharing options...
ballitch Posted January 29, 2005 Share Posted January 29, 2005 cmon doc, ive got a 1990 legacy wagon. ~Josh~ Link to comment Share on other sites More sharing options...
dragonlee2 Posted January 29, 2005 Share Posted January 29, 2005 4dr hatch? are you including the hood in this count??? does it look like this: called a "hatch" or like this: normally called a "3dr" It's a wagon with a hatch Link to comment Share on other sites More sharing options...
Turbone Posted January 29, 2005 Share Posted January 29, 2005 The 2 top pics are what we refer to as "Hatches/Hatchbacks". You just have a plain jane Wagon. And I was always taught to question authority Link to comment Share on other sites More sharing options...
Dr. RX Posted January 29, 2005 Share Posted January 29, 2005 didnt the legacy wagons start in 1990? My friends mom drives a 91 turbo 5spd sedan.Yes, the wagons were available in 1990, but the trubos didn't start until 1991. Link to comment Share on other sites More sharing options...
Dr. RX Posted January 29, 2005 Share Posted January 29, 2005 cmon doc, ive got a 1990 legacy wagon. ~Josh~ ??????????? I'm not sure what you are refering to here, someone ask if the wagons started in 1990, your reply seems to say that I said something to the contrary, I don't think I did. By the way, I just nswer the other person's question. Link to comment Share on other sites More sharing options...
Dr. RX Posted January 29, 2005 Share Posted January 29, 2005 Ok you asked if it had a small or big window but then didn't say which is which. My 88GL is a four door with a hatch, the window is half the hatch. So what would that make it?If you have 4 doors and a hatch, it's a wagon. Link to comment Share on other sites More sharing options...
dragonlee2 Posted January 30, 2005 Share Posted January 30, 2005 If you have 4 doors and a hatch, it's a wagon. Ok so is it EA81 or EA82 Link to comment Share on other sites More sharing options...
bushbasher Posted January 30, 2005 Share Posted January 30, 2005 ??????????? I'm not sure what you are refering to here, someone ask if the wagons started in 1990, your reply seems to say that I said something to the contrary, I don't think I did. By the way, I just nswer the other person's question. Dragonlee, I'd like to see that 90 Impreza, it is rare, considering that Subaru didn't make an Impreza until 1993. Lol sorry Legacy, was looking at pictures of Imprezas. Same answer holds true for Legacys. There ya go. Link to comment Share on other sites More sharing options...
Turbone Posted January 30, 2005 Share Posted January 30, 2005 Dragonlee, yours is a EA82 engine. It has timing belts, OHC and a llittle more HP than the EA81's do. Also came with a 5spd dual range tranny, which can be mated to a EA81 engine(with a few mods). Link to comment Share on other sites More sharing options...
Dr. RX Posted January 30, 2005 Share Posted January 30, 2005 There ya go. I guess that is what happens when you don't know who someone is responding to. My answer, "The same goes for Legacys" was not in reply to dragonlee's reply about that he meant a Legacy. You should be a news reporter, you have a good start at taking things out of context. Link to comment Share on other sites More sharing options...
Dr. RX Posted January 30, 2005 Share Posted January 30, 2005 Ok so is it EA81 or EA82Eventhough Rob has aready answered, here is a rule to go by without look at the engine; car from 1980 to 1984 were generally EA81s (some EA71s in there), from 1985 to 1989 they were EA82s, this rule doesn't include the BRAT and the Hatchback (not to be confused with the 3 door). There were EA82s from 1990 to 1994, but there were also Legacys and Imprezas in that time frame. It only applies to 4 cylinder cars. Link to comment Share on other sites More sharing options...
bushbasher Posted January 30, 2005 Share Posted January 30, 2005 My answer, "The same goes for Legacys" was not in reply to dragonlee's reply about that he meant a Legacy. You should be a news reporter, you have a good start at taking things out of context. Oh look, there we go, right into the personal attacks! We all know you have your ego to protect right?! Your explanation doesnt make any sense, and I'm sure people will draw their own conclusions. Link to comment Share on other sites More sharing options...
MilesFox Posted January 30, 2005 Share Posted January 30, 2005 if your car is turbo with a 5spd or full time 4AT the legacy/impreza/xt6 axles will fit on the tranny. if its a non turbo, or a turbo with a 3spd AT the axles wont fit on the tranny. BUT you can swap the 23 spline doj from a 3at turbo axle onto the leg/imp/xt6 axles to match a non turbo 5spd this part is key but no one ever mentions it Link to comment Share on other sites More sharing options...
