Phaedras Posted January 28, 2005 Share Posted January 28, 2005 Well now, short of taking everything apart and scrubbing it seperately, what do you guys use to degunk your fuel system? Are there any preferred cleaners? Do you do a couple in quick succession? HAS someone actually stripped their fuel system and scrubbed it by hand? Do you use seperate cleaners for injectors and general fuel system? Is it particularly important to use stock filters, pumps, etc.? Any ways of optimizing the system? Thank you for your replies. Link to comment Share on other sites More sharing options...
Cougar Posted January 28, 2005 Share Posted January 28, 2005 Sorry I can't help you with this. In over 38 years of driving and filling vehicles with gas, I have never done that or needed to. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted January 28, 2005 Share Posted January 28, 2005 MMO! Marvels Mystery Oil Thats what I use and it works great. -Brian Link to comment Share on other sites More sharing options...
calebz Posted January 28, 2005 Share Posted January 28, 2005 Berrimans B-12 is good too.. just don't use too much Link to comment Share on other sites More sharing options...
moshem74 Posted January 28, 2005 Share Posted January 28, 2005 hi METHANOL is the answer. methanol is the best fuel cleaning and gives you more performance.... i use it all the time , i buy 18litter each time, it cost me less then fuel,i put it in the fuel tank 1 litter every time i put gas. http://www.green-trust.org/2000/biofuel/dwg/dwgch3.htm big improvment. moshe. Link to comment Share on other sites More sharing options...
Snowman Posted January 28, 2005 Share Posted January 28, 2005 I've worked the past three summers at a fuel/petro company, and the ONLY product for pouring in the tank that we guarantee will do something is Chevron Fuel System Cleaner (Techron Concentrate). I now run the stuff at every oil change. My mom's old wagon was all gummed up after years of around-town driving, so I poured in a bottle of the stuff and the mpg jumped at least 5 just from doing that. Link to comment Share on other sites More sharing options...
TomRhere Posted January 28, 2005 Share Posted January 28, 2005 Use the Chevron stuff myself, it's great. I've even dumped 2 bottles in the same tank of gas on a couple of vehicles. It does get the grud out. Link to comment Share on other sites More sharing options...
Qman Posted January 28, 2005 Share Posted January 28, 2005 The best stuff I have ever used is Redline synthetic fuel system cleaner. I used it on an old Chev truck I had. The secondaries were gummed up and not functioning. It cleaned everything right up and never had to do a rebuild on it. I have used it religiously ever since, about 10 years! And recommend it to all who ask. Link to comment Share on other sites More sharing options...
erik litchy Posted January 28, 2005 Share Posted January 28, 2005 The best stuff I have ever used is Redline synthetic fuel system cleaner. I used it on an old Chev truck I had. The secondaries were gummed up and not functioning. It cleaned everything right up and never had to do a rebuild on it. I have used it religiously ever since, about 10 years! And recommend it to all who ask. sounds like good stuff Link to comment Share on other sites More sharing options...
MorganM Posted January 28, 2005 Share Posted January 28, 2005 Sea Foam; accept no substitutes Link to comment Share on other sites More sharing options...
Phaedras Posted January 28, 2005 Author Share Posted January 28, 2005 I'm wondering where you can buy pure methanol. I know some of the off-the-Autozone-shelf cleaners have methanol in them, but it's usually a blend. But I would like to burn 2-3 tanks with just pure 10% methanol in them to test it out. Link to comment Share on other sites More sharing options...
Skip Posted January 28, 2005 Share Posted January 28, 2005 you would be well advised to do a Google search on the dangers of using meth. too much is not a good thing and you can easily do more harm than good please suit yourself but concentrations as high as you say are not recco'd some fuel system components and meth do mix literally Link to comment Share on other sites More sharing options...
Phaedras Posted January 28, 2005 Author Share Posted January 28, 2005 Well, has anyone heard any horror stories about methanol? It sounds fairly intriguing. What about a 5% blend? Or is Ethanol a safer fluid? Besides that, where can I purchase these volatile substances? Link to comment Share on other sites More sharing options...
idosubaru Posted January 28, 2005 Share Posted January 28, 2005 what makes you think you need such an exhaustive fuel system treatment? fuel delivery should be fine on your car. send the injectors off to RC engineering to be professionally cleaned, rebuilt and flow tested if you have legitimate reasons for concern. i've used lots of different fuel additives, with no result. i've also never experienced any fuel related issues with 3 motors at 200,000+ miles, so it really didn't matter. Link to comment Share on other sites More sharing options...
85Sub4WD Posted January 28, 2005 Share Posted January 28, 2005 I actually use MMO in the crankcase and only put in gas for decarbonizing the heads, and cylinders. Too much will clog a carb (found out the hard way). I use Techron in the gas tank, and with a good abount of sucess for cleaning injectors and intake valves. It depends on what you want to clean as to what you should use. Running MMO and then Techron would probably give you the best cleaning combination (do not mix in same gas tank at same time). Link to comment Share on other sites More sharing options...
thedoctor Posted February 1, 2005 Share Posted February 1, 2005 Just an update on my incredibly frustrating:banghead: no start in cold weather. I was faced with a carb rebuild on a Carter-Weber --who would even want to do that-- so I tried Chevron Techron Concentrate -- and so far I've had immediate starts, that surging at cruising speed is gone, and the dieseling stopped. I'm ready for some single digit nights now. Thanks for the great information. PS I do have another engine lined up, EA81 with 116K on it. It has a Hitachi carb. I'm still thinking of picking it up to play with (I can get it for $50 -80, depending on the deal) What do you think? I've worked the past three summers at a fuel/petro company, and the ONLY product for pouring in the tank that we guarantee will do something is Chevron Fuel System Cleaner (Techron Concentrate). I now run the stuff at every oil change. My mom's old wagon was all gummed up after years of around-town driving, so I poured in a bottle of the stuff and the mpg jumped at least 5 just from doing that. Link to comment Share on other sites More sharing options...
4WDFrenzy Posted February 1, 2005 Share Posted February 1, 2005 I would suggest using SeaFoam, Berryman's B-12 Chemtool(for those times when you have neglected your fuel system for a while), and Marvel Mystery Oil. All of these work excellent in my past experiences. Link to comment Share on other sites More sharing options...
