diluded000 Posted January 28, 2005 Share Posted January 28, 2005 If it doesn't snow, I might be doing the rear disk brake conversion on my 85 DL this weekend, and would like to upgrade the soft (on a couple of levels) hoses on the front at the same time. This is really more of a generic brake line question, than a transplant so: can I just go up to the local NAPA/Auto Zone/Advance and buy braided stainless brake lines off the shelf? What am I looking for anyway, a banjo bolt on one end and a 10mm fitting on the other? Any help with how to describe what I need, or where to get it would be a huge help. Thanks. - James B Link to comment Share on other sites More sharing options...
MorganM Posted January 28, 2005 Share Posted January 28, 2005 No banjo bolt fittings. They have female fittings at each end of the softline. ID is 3/16" WJM has the hook up on the stainless steel bolt-on softlines but any brake warehouse/shop can hook you up too. I had custom softlines made at a local brake shop. Link to comment Share on other sites More sharing options...
rallyruss Posted January 28, 2005 Share Posted January 28, 2005 yeah talk to WJM he had some avl. a while back. I got a set from him and never had time to put them on. still sitting in the garage. Link to comment Share on other sites More sharing options...
WJM Posted January 29, 2005 Share Posted January 29, 2005 Still have them avalible. JWX has information on using these same lines on the REAR DISC EA82 cars. Link to comment Share on other sites More sharing options...
PoorManzImpreza Posted January 29, 2005 Share Posted January 29, 2005 Will, did you perform the install on your rear lines as well? Link to comment Share on other sites More sharing options...
WJM Posted January 29, 2005 Share Posted January 29, 2005 PoorManzImpreza said: Will, did you perform the install on your rear lines as well? No. I lack t3h $. JWX is mr money bags and did the rear lines. Fronts are a 100% direct bolt up. Link to comment Share on other sites More sharing options...
carfreak85 Posted March 11, 2006 Share Posted March 11, 2006 Will, are there any sets of these still around to be purchased? Looking for a set for my wagon. Link to comment Share on other sites More sharing options...
WJM Posted March 11, 2006 Share Posted March 11, 2006 Call 1-828-210-3623, ask for Kent (thats his direct line, he should answer it, Monday thru Friday, 8am to 5pm), and ask for the TWR SS line set. Link to comment Share on other sites More sharing options...
carfreak85 Posted March 11, 2006 Share Posted March 11, 2006 WJM said: Call 1-828-210-3623, ask for Kent (thats his direct line, he should answer it, Monday thru Friday, 8am to 5pm), and ask for the TWR SS line set. What does the set include and what does it run? Link to comment Share on other sites More sharing options...
WJM Posted March 11, 2006 Share Posted March 11, 2006 all 4 lines. all hardware for the front. The back you need a slightly shorter banjo bolt, or double washer the back and make sure it doesnt leak. these sets are designed for WRX and all other EJ subies. However, I have used them on EA's perfectly. Link to comment Share on other sites More sharing options...
Caboobaroo Posted March 11, 2006 Share Posted March 11, 2006 saweet... I know what I'm getting:brow: Link to comment Share on other sites More sharing options...
nkx Posted March 11, 2006 Share Posted March 11, 2006 i should call on monday. my pedal is plenty firm, i just need protection from pads catching on fire. Link to comment Share on other sites More sharing options...
carfreak85 Posted July 28, 2008 Share Posted July 28, 2008 WJM said: these sets are designed for WRX and all other EJ subies. However, I have used them on EA's perfectly. So could I just buy a set of WRX front and rear lines from my manufacturer of choice and simply bolt them on? Link to comment Share on other sites More sharing options...
ahole Posted July 28, 2008 Share Posted July 28, 2008 Whoaa! This thread is back from the dead! Link to comment Share on other sites More sharing options...
Subarutex Posted July 29, 2008 Share Posted July 29, 2008 carfreak85 said: So could I just buy a set of WRX front and rear lines from my manufacturer of choice and simply bolt them on? Basically, yah. I have them in the fronts of my RX. Not the back yet. Link to comment Share on other sites More sharing options...
Numbchux Posted July 29, 2008 Share Posted July 29, 2008 pretty sure the rear EJ lines have banjo bolts like the front. so I don't think they'd work on EA subies. Link to comment Share on other sites More sharing options...
presslab Posted July 29, 2008 Share Posted July 29, 2008 I have Goodridge WRX front & rear SS hoses on mine. In the front where it goes through the strut it is a little too big, so the clip doesn't fit perfect...but it works. In the rear there is no mount for the center attachment, so I put some rubber hose over the SS hose so it wouldn't rub on the attachment point. The banjo bolt on the rear was no problem, I used the ones included in SS hose package. I lightly sanded the sealing surface on the caliper and it bolted together, no leaks, no problem. Link to comment Share on other sites More sharing options...
carfreak85 Posted September 16, 2008 Share Posted September 16, 2008 presslab said: I have Goodridge WRX front & rear SS hoses on mine. So your's just bolted on without many mods? What vehicle is this on? Link to comment Share on other sites More sharing options...
baccaruda Posted September 16, 2008 Share Posted September 16, 2008 for what it's worth, I had a complete set made for my wagon at a local hydraulic shop. I brought them complete junk rubber line sets from the junkyard - 1 front, 1 back - and said "make me these from SS." Oh yeah, and I added 4" so I wouldn't have to fink with adjusting my lifted wagon's brake line brackets My set cost me around $100. Link to comment Share on other sites More sharing options...
presslab Posted September 16, 2008 Share Posted September 16, 2008 carfreak85 said: So your's just bolted on without many mods? What vehicle is this on? Yes, just the mods I listed. The car is an '88 GL-10 wagon with rear disc. Link to comment Share on other sites More sharing options...
