thedoctor Posted January 28, 2005 Share Posted January 28, 2005 How can I tell what carb I have for sure. I am going by the linkage connecting on the driver's side = Carter-Weber, but I make some stupid mistakes. I need to know for sure. Also if it is a Carter-Weber, I need to do all possible cleanings because rebuild is not an option. Would you recommend soaking it in something? Or is MMO or some similar system cleaner just as good. Quote Link to comment Share on other sites More sharing options...
Skip Posted January 28, 2005 Share Posted January 28, 2005 C-W is a single barrel carb Hitachi is a two barrl. carb Chevron is a good cleaner as is Seafoam Quote Link to comment Share on other sites More sharing options...
Mudboat Posted January 28, 2005 Share Posted January 28, 2005 The Carter-Weber should have a metal tag on the front, right, bottom side on one of the bolts. The C-W tag has the carb info. Quote Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted January 29, 2005 Share Posted January 29, 2005 I have an old carter weber out of my brat, has like 144K on it. Ran good when warm, got about 25 MPG in town. I think the choke wasnt set right because it didnt run that smooth for the first 1-2 minutes, but after that it was great. I have the entire intake manifold so you can pick and choose the parts you want. PM me if interested and we can work out a price Quote Link to comment Share on other sites More sharing options...
85Sub4WD Posted January 29, 2005 Share Posted January 29, 2005 I have not found that MMO is good at breaking down grime unless it is at a fairly high temp, in fact I had it grunge-up a carb on me once, so I would not recomend soaking it in that or anything. Carb soaking is usually done before a rebuild to break all of the old seals loose (You do not want that to happen!!!) Techron is probably the best fuel additive, run a tank through and you should be fine. Quote Link to comment Share on other sites More sharing options...
thedoctor Posted January 29, 2005 Author Share Posted January 29, 2005 Thanks for the good information. I found that metal tag so I know it is a C-W. I sure won't soak that carb. If the fuel system cleaner(s) don't fix my cold start problem, I'll be in the market for a Hitachi carb with intake manifold. I can at least get a rebuild kit for that. I have an old carter weber out of my brat, has like 144K on it. Ran good when warm, got about 25 MPG in town. I think the choke wasnt set right because it didnt run that smooth for the first 1-2 minutes, but after that it was great. I have the entire intake manifold so you can pick and choose the parts you want. PM me if interested and we can work out a price Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted January 29, 2005 Share Posted January 29, 2005 one thing about the Carter-Webers is that trying to get parts from anywhere including the dealership won't happen! I needed a part for the one on my '83 hatchback and the only place I found one was at a hobby store. It sucked but I ended up getting rid of the car since it was a giant rust bucket and ran like crap. Traded it straight across for my '79 4wd wagon:D Gen 1's ROCK!!! Quote Link to comment Share on other sites More sharing options...
