Stupid Previous Owners!
My '92 Loyale died a few weeks ago in some bitterly cold weather. It had all the symptoms of a timing belt failure, but when I checked, both belts were still there. I looked at the spark timing next, and it was all over the place! I couldn't figure it out.
Anyways, to make a long story short, I took the belt covers off, and found the problem. When the previous owner had the timing belts changed, whoever did the work only used 1 bolt on the drivers' side tensioner instead of 2. The second bolt wasn't there at all. The tensioner was loose, and the drivers' side belt had zero tension. I pulled a bolt off a parts car I have, put it in, and now it's working fine.
Grr! At least it gave me an excuse to take the timing belt covers off.
