Subaru recommended timing belt replacement
105,000 is the recommended service interval - I've yet to see one on the later model engines break. If you stick to the manufacturer's recommended service intervals, you'll be fine.
  benking said:
Subaru recommends changing your timing belt every 105,000 miles on a 2000 or newer model. Do you think this is right or should it be done more often? Will it destroy the engine on a 2000 legacy if the belt does break? I found that service interval here:
http://www.cars101.com/subaru/subaru_maintenance.html
Ben
The newer engines are interference head, so if the T-belt goes, it will destroy the engine.
That said, follow what Subaru recommends, and double-check with your owner's manual - don't let a 3rd party's mistake cost you a broken T-belt.
