subyrally Posted January 31, 2005 Share Posted January 31, 2005 projector headlights for 82=87 brats http://www.speedyautoparts.com/cgi-bin/speedy/SUBRATUN9901PHL8287.html?source=ink front fenders for hte 82 http://www.speedyautoparts.com/cgi-bin/speedy/SUBRAT22.html Link to comment Share on other sites More sharing options...
carfreak85 Posted February 1, 2005 Share Posted February 1, 2005 Hmmmm, projector headlights? This sounds interesting... Wonder what the beam pattern is like... Link to comment Share on other sites More sharing options...
Qman Posted February 1, 2005 Share Posted February 1, 2005 Looks like the only fit single headlight models. Large squarish replacement lights. Link to comment Share on other sites More sharing options...
subyrally Posted February 1, 2005 Author Share Posted February 1, 2005 i thought hte single light cars had a much wider light fixture. Link to comment Share on other sites More sharing options...
RavenTBK Posted February 1, 2005 Share Posted February 1, 2005 The projector wannabe lights replace H6054 lights. The 6054 is used in the DL, 2 light models. Only those with two, 200mm lamps. Either way, they suck. A poor excuse for a headlamp.. especially at $50 each! Hell, the 490 watts I have running out of my headlamps now cost me less than $85. That was for a set of FOUR E-Code lamps (H4 hi/low and H1 highs), and customized relay harness. Please.... Link to comment Share on other sites More sharing options...
subyrally Posted February 1, 2005 Author Share Posted February 1, 2005 eh, just thought it was interesting, something different. Link to comment Share on other sites More sharing options...
RavenTBK Posted February 1, 2005 Share Posted February 1, 2005 Ah grasshopper, the grass is not always greener... Yes it would be different.. a bit too different IMO. Looks like you've got a damn zit growing in the middle of your headlight. Can I pop it? I see they list them as having glass lenses. Whats the housing made of? Most likely its plastic, being from china and all. The plastic housing would not allow you to run any higher wattage bulbs. If you did, you'd melt the housing. Either way, $50/ea is just a bit too rich for my blood. I dunno. If you've got a 2 light DL setup, they'd swap in fine if you really want to do it. If you really want some projector lamps.. check these out: http://www.rallylights.com/hella/90mm_modules.asp I've been considering getting a set of those to swap into my Bronco to get rid of the stupid big plastic aerodynamic lights. I'd have to fab it all up, including a cover to fill in the large gap that would be left around the modules, but I think it would look wicked with four pod lights instead of the huge volvo-esque plastic housings. Think 96ish Acura Integra lights..thats what they look like installed. Link to comment Share on other sites More sharing options...
subyrally Posted February 1, 2005 Author Share Posted February 1, 2005 not bad. i still want the hella rally lights though, pity they arent street legal Link to comment Share on other sites More sharing options...
RavenTBK Posted February 1, 2005 Share Posted February 1, 2005 I think I should post up the sources I had for my E-codes and part numbers.. the harness was an off the shelf style upgrade harness with some re-routing between the relays to deal with the quirky Subaru ground switching setup. The lamps themselves are glass housings with polished aluminum reflectors. Best upgrade I have ever done to any of my fleet. Anywho, the GF just called and has requested that I rush over there to "see her". Gee.. "see her" or post up boring headlight facts? I'll post later! Link to comment Share on other sites More sharing options...
subyrally Posted February 1, 2005 Author Share Posted February 1, 2005 run to your lady friend, and enjoy every second you have together. shesmore important than aftermarket lighting Link to comment Share on other sites More sharing options...
