Check engine light come on, I got the codes pulled...P0325 (Knock sensor circuit malfunction.) Autozone has them for like $38. I know where it is, and it looks like it can be done in the driveway. My question is, will there be coolent pouring out when I take it out? Any tips would be cool.
-Matt.
-Matt.
No coolend will come out. Make sure the new sensor is positioned correct (watch where the wire comes out from the sensor, that spot should not touch the engine) otherwise you crack it when you tighten the bolt.
