Question concerning the interchangeing of air flow meters
if its a flapper system, run any flapper maf.
no diff between turbo, na, or 6 cylinder
Not what the parts book says.
3 different, turbo,85 MPI,86+ MPI
No interchangability indicated.
No 6 cyl. flappers
85-86 maf for turbo and non turbo mpfi is the same. the only other MAF for that year is the 86.5 spdi, which will not work
i believe ea81T (83-84) maf will work, since it has the vane style MAF and the MPFI system is very similar
No 6 cyl. flappers
parts books huh... does it say that the fuel pumps are interchangable between any efi model? does it say you can put a spider intake on a flapper mpfi motor? does it say you dan rage an er27 in an 86 hatchback?
didnt think so.
miles pointed out the only exception afaik.
Forget "the book", my 1985 FSM has complete info for both systems, and the MAF is the same for both, in fact the computer is the same for both non-turbo and turbo cars, there is a difference in grounding of a pin so the computer knows what it is plugged into. It will be a vane - type system b/c it is 1986, so a vane - type MAF will work. The 85 and 86 cars are the same for the turbo system, remember this is a Subaru where almost everything is interchangeable, it will work.
"a difference in the grounding of a pin"...Is this something I need to be concerned about...for ex.... rewireing of connectors so as to get proper grounding..or is it just a matter of clipping the connector on...
