jeff303 Posted August 25, 2003 Share Posted August 25, 2003 I have an 85 GL non turbo. The blower motor does not come on at all, I hooked it up to a battery and it worked fine. Replaced the blower resistor pack and it still does not come on. Someone mentioned the AC/Heater switch may be the problem. Does anyone have any opinions on this problem? Please help Thanks in advance Link to comment Share on other sites More sharing options...
NoahDL88 Posted August 25, 2003 Share Posted August 25, 2003 I had a problem like that try pulling out the 4 speed switch a little and shimming it with paper, thats what i had to do to get mine working Link to comment Share on other sites More sharing options...
calebz Posted August 25, 2003 Share Posted August 25, 2003 EDIT: Never mind my advice.. I just re-read your post and saw that you already replaced the resistor pack. BTW.. Its nice to hear of another old school soob in texas. Link to comment Share on other sites More sharing options...
Marck Posted August 25, 2003 Share Posted August 25, 2003 Check the fuses. If the fuse(s) for the blower is good, then check the relay. There are four relays above the fuse box. One of those is for the blower. I had the same problem and the culprit turned out to be the relay. If the fuses and relay are good, then the problem may be the switch. Link to comment Share on other sites More sharing options...
