amica Posted February 3, 2005 Share Posted February 3, 2005 I have a 93 Subaru Justy, and the clutch temp warning is on even after I start the engine and it is running. Any advice? I don't know if I can still drive this car with this warning light on, the nearest dealer is 300km far away from my place and I don't if it safe to drive it that far. Please advice Also the (number 8) fuse (15A) for my signal light and grear shift lock shorted all the time. Anyone can help me? Thank you Ami Link to comment Share on other sites More sharing options...
85Sub4WD Posted February 3, 2005 Share Posted February 3, 2005 Sounds like a bad ground issue. I would check all circuits involved for bad grounding, wires, etc. I don't think US justys have the clutch temp warning light, but I wouldn't know as I drive a GL (Leone). Good Luck!! Link to comment Share on other sites More sharing options...
Skip Posted February 3, 2005 Share Posted February 3, 2005 Ami, Welcome to the USMB but I do think you question will be better served at the Justy Only Board here is a link to it http://subarujusty.proboards20.com/ good luck Link to comment Share on other sites More sharing options...
amica Posted February 4, 2005 Author Share Posted February 4, 2005 Thanks You. I will try your suggestion. Ami QUOTE=85Sub4WD]Sounds like a bad ground issue. I would check all circuits involved for bad grounding, wires, etc. I don't think US justys have the clutch temp warning light, but I wouldn't know as I drive a GL (Leone). Good Luck!! Link to comment Share on other sites More sharing options...
amica Posted February 4, 2005 Author Share Posted February 4, 2005 Thanks A lot! I will try this link! Ami Ami,Welcome to the USMB but I do think you question will be better served at the Justy Only Board here is a link to it http://subarujusty.proboards20.com/ good luck Link to comment Share on other sites More sharing options...
