HELP!!! on ocassion the car will sound like it is going to die when i hit the accelerator and then i shift it in to first and it still sounds like its going to die then i shift it into neutral and rev it up and the problem goes away it is an auto and tomarrow im going to change the fluid is there anything else i can do to find out the the problem might be or how to fix it? it is a 90 legacy awd
ill have to check it out in the morning now but i did fill the one on the passside, thank for the help thats probally what it is, where is the front differential fluid plug located at and do i have to change the rear one too?
