camosuba Posted August 25, 2003 Share Posted August 25, 2003 Can anyone tell me will a drum brake rear hub for a awd 98 impreza interchange with a 92 legacy awd rear hub? I have found some cheap hubs and am wondering if they will fit my legacy? thanks in advance camo Link to comment Share on other sites More sharing options...
rallynutdon Posted August 25, 2003 Share Posted August 25, 2003 They should. But isn't your Legacy disc brakes? Why whould you want to swap to drums? Link to comment Share on other sites More sharing options...
Subie Gal Posted August 25, 2003 Share Posted August 25, 2003 the 1998 AWD impreza (RS/OBS) was rear disc as well AS A MATTER OF FACT... the 98 impreza and 1992 Legacy have the same rear hubs... part ##26750AA014 exact... same... part number so yes, they will fit Jamie (<---i work for subaru ) Link to comment Share on other sites More sharing options...
rallynutdon Posted August 26, 2003 Share Posted August 26, 2003 But he said "drum brake rear hub" Link to comment Share on other sites More sharing options...
gravelRX Posted August 26, 2003 Share Posted August 26, 2003 the rear emergency brake "drum" inside the hat? It's all one piece. Jay Link to comment Share on other sites More sharing options...
Subie Gal Posted August 26, 2003 Share Posted August 26, 2003 Originally posted by rallynutdon But he said "drum brake rear hub" ahh that he did.... and even STILL the WHEEL hubs are the same part numbers... unless he's referring to some other part specific to the drum brakes??? oh well.. i tried.. i'll help if i can... jamie Link to comment Share on other sites More sharing options...
camosuba Posted August 30, 2003 Author Share Posted August 30, 2003 thanks for the replies but i have since discovered that to remove the backing plates to swap over to the discs you have to remove the drive flange and that damages the bearings so i have replace them anyway so i'll do my own instead Link to comment Share on other sites More sharing options...
