Changing the disty in my wagon, is there any tricks I should know?
make sure the vac. advance unit works on the replacement BEFORE you install it!!!!!
install it at tdc #1 you can find tdc #1 by pulling iut #1 sparkplug and sticking your finger in the hole so you can feel air pressure, then make sure the pointer is at 0*
now pull out the dist. the rotor should be pointed between #1 and #3!!!!!
then slide in the replacement, and set timing with advance line disconnected and plugged
after timing is set, hook up advance line to manifold, and the timing should be 20*+, now increase rpm and see if advance decreases
Advance should increase w/increasing rpm,not decrease.
Good advice re checking the vacuum advance.
No need to fool around pulling spark plugs to put #1 at TDC.
Just mark the rotor position relative to the housing before pulling the original disty and install the new one w/the same relative orientation.
