Oily Residue in Breather? Cause?
I had this prob, and "fixed" it by installing a filter such as is found on a pneumatic compressor. the filter was inside a can thing with an inlet and outlet hose fitting. I simply installed this into the line, and emptied the oil in the bottom into the engine every now and again...
A little crude, but it worked..
THe line going from the rocker cover to the filter box - this was an new zealand ea81 - very simple no emmisions, so yours may be different.
I havn't replaced the rings, the enigne is sitting in teh garage as the car is off hte road at the moment. I think a valve is at fault in my case (not seating properly), as the enigne had new rings only about 80,000 kms ago.
