arbee524 Posted February 7, 2005 Share Posted February 7, 2005 I have a 2000 Legacy L and am experiencing the same transmission hesitation problem going into drive, and it has recently become worse. You mention in several posts about a TSB for "transmission delayed engagement (defective seal)". I followed your link to the NHTSA TSB web site, but the closest problem I could find was under "POWERTRAIN" and read "TRANSMISSION CONTROL UNIT (TCU) CODE 45 AND ALL-WHEEL DRIVE HARSH ENGAGEMENT." Is that the one you were talking about? or is there someplace else I should look. Is it possible the TSB was removed? I'm bringing the car to Subaru this Thursday and wanted to have as much info as possible before I go. The car has just over 60K (60,800) miles so I don't know if they will warranty whatever they find wrong. Thanks for any advice you can offer. Link to comment Share on other sites More sharing options...
arbee524 Posted February 8, 2005 Author Share Posted February 8, 2005 bump Link to comment Share on other sites More sharing options...
brus brother Posted February 8, 2005 Share Posted February 8, 2005 I have a 2000 Legacy L and am experiencing the same transmission hesitation problem going into drive, and it has recently become worse. You mention in several posts about a TSB for "transmission delayed engagement (defective seal)". I followed your link to the NHTSA TSB web site, but the closest problem I could find was under "POWERTRAIN" and read "TRANSMISSION CONTROL UNIT (TCU) CODE 45 AND ALL-WHEEL DRIVE HARSH ENGAGEMENT." Is that the one you were talking about? or is there someplace else I should look. Is it possible the TSB was removed? I'm bringing the car to Subaru this Thursday and wanted to have as much info as possible before I go. The car has just over 60K (60,800) miles so I don't know if they will warranty whatever they find wrong. Thanks for any advice you can offer. Sorry I didn't see the message until just now. Always best to send a Private Message through the board if you want to contact a member. Look at the top right corner of your screen and see under Private Message. I've even been successful getting a moderator to contact a member when they hadn't enabled e-mail or PM contacts on their profile. Basically, the mechanic was able to diagnose it here at Dan Perkins Subaru in CT. based on symptoms. He confirmed it with a test drive and then gave the knowing look to the service manager of "yup, another one". It had to do with a seal not sealing and defective hydraulics within the trany as a result. Hopefully you are still covered under the 5yr/60K drive train warranty or can make the case that it has been going on for a while but only got so bad that you thought to complain. Send me a PM if you need further clarification. The following post might also relate to your problem. I never knew to even look for a "code". G'luck Make : SUBARU Model : LEGACY Year : 2000 Manufacturer : SUBARU OF AMERICA, INC. Service Bulletin Num : 166602 Date of Bulletin: MAR 15, 2003 NHTSA Item Number: 10001352 Component: POWER TRAIN Summary: TRANSMISSION CONTROL UNIT (TCU) CODE 45 AND ALL-WHEEL DRIVE HARSH ENGAGEMENT. *TT Link to comment Share on other sites More sharing options...
