Scano Posted February 8, 2005 Share Posted February 8, 2005 Is it possible to fit an EA81 into an 83 DL wagon? If so are there an modifcation or parts issues? The engine that is currently fitted is an EA82. Link to comment Share on other sites More sharing options...
Turbone Posted February 8, 2005 Share Posted February 8, 2005 Over here the 83 DL had a EA81 from the factory. Was the EA82 in yours a retrofit? Link to comment Share on other sites More sharing options...
mcbrat Posted February 8, 2005 Share Posted February 8, 2005 I'm running an ea81 engine in my 87 wagon..... Link to comment Share on other sites More sharing options...
MorganM Posted February 8, 2005 Share Posted February 8, 2005 Sure, it'll fit Shouldnt be to bad of a motor swap too seeing how the EA81 is carbed. If your EA82 is SPFI you might look into the SPFI upgrade onto the EA81 engine. There is a write up here on it. http://www.ultimatesubaru.org/forum/showthread.php?t=28620&highlight=ea81+spfi+conversion Glad to have you here; but you might find some local help at http://www.ausubaru.com . They have a forums section and such. Might find someone in your area willing to help! Good luck Link to comment Share on other sites More sharing options...
Scano Posted February 9, 2005 Author Share Posted February 9, 2005 Thanks for the good info. The car came standard in 83 with the EA82. I will look into it further and check out the aus site. I will let you know how I go, Cheers from down under. Scano. Link to comment Share on other sites More sharing options...
JWX Posted February 9, 2005 Share Posted February 9, 2005 I think they got the EA82 styled ones earlier down under Link to comment Share on other sites More sharing options...
Ross Posted February 9, 2005 Share Posted February 9, 2005 You sure about the whole ea82 in an 83 bit??? We sure don't have ea82 styles in 83 in New Zealand, and we usually get the same models as Australia.... Link to comment Share on other sites More sharing options...
