Syonyk Posted February 10, 2005 Share Posted February 10, 2005 I'm trying to figure out if something is wrong with my engine, or if I'm just not used to a somewhat underpowered vehicle. Merging onto the highway, I usually end up doing 50mph or so at the end of the ramp, less if it's uphill (there's one particular ramp I'm lucky to be doing 40 at the top of). It takes something resembling an eternity to get up to cruising speed, in the 20+ second range. Cruising is 70mph or so. In 5th gear, on a good highway hill, I have to hold WOT to maintain 75mph. Is this normal, or should I be investigating my engine and related parts for some sort of blockage? -=Russ=- Link to comment Share on other sites More sharing options...
kingbobdole Posted February 10, 2005 Share Posted February 10, 2005 My 87 DR carbbed wagon does about the same... only 84 horse for me, but I dont really expect much. Link to comment Share on other sites More sharing options...
MudisFun Posted February 10, 2005 Share Posted February 10, 2005 I got my old EA82 SPFI with 5 speed up to 88mph before I got worried. I even think that reaching 50mph just off the ramp was a good deal. Link to comment Share on other sites More sharing options...
hooziewhatsit Posted February 10, 2005 Share Posted February 10, 2005 Have you done the basic tune up stuff? (plugs, cap, wires, etc) What are your shift points? If I REALLY have to get up and go, I'll hold third until 55 or 60, which then puts 4th right into the power band as well. Link to comment Share on other sites More sharing options...
Syonyk Posted February 10, 2005 Author Share Posted February 10, 2005 Planning to do some tuneup stuff this weekend. It could use new plugs/wires/timing belts. I'm a bit afraid to wind it up really tight because I know the timing belts are old. The driver's side belt especially. I'm getting better at holding it in a gear until high RPMs. My other car is a rotary, and it winds up to 7k-8k before complaining (actually, before fuel cut). I'm not used to a piston engine enjoying being wound out. I'll try holding 3rd to 55 sometime and see if it helps. I'm sort of planning to punch out/remove the cats and see how much I gain there. How does a straight piped Subaru sound? -=Russ=- Link to comment Share on other sites More sharing options...
ballitch Posted February 10, 2005 Share Posted February 10, 2005 that is pretty much the standard for the EA82 or EA81's not alot of power to be expected from them, if you do the spfi swap you will nab about an extra 10 horse and be a little better to drive, but sounds like just plain jane old school slow-bie. ~Josh~ Link to comment Share on other sites More sharing options...
MilesFox Posted February 10, 2005 Share Posted February 10, 2005 shift at a piont where the rpms land around 3500 in the next gear, dont be afraid to take it to 4500 between shifts. subarus have a short throw crank and the power comes on between 3000 and 4000 rpm if you are shifting at like 2-2500 rom the motor will just not touch its powerband one example is baja'n in mud. to the floor at 25oo and nothing exciting, bog bog bog. but if you can bog your way up to 3-3500 rpm in the same mud the tachometer takes off like a roket anyway i make laps in the field all day at 5500 rpms and the mtor doesnt complain i coudl agree with not wanting to break the old timing belt. you can get the rpms up and be ok just be gradual Link to comment Share on other sites More sharing options...
Syonyk Posted February 10, 2005 Author Share Posted February 10, 2005 How much does advancing the timing help? I'm planning to do a "European timing set" once I do the tuneup... advance timing until it pings, then back off a bit. I also just discovered that my left rear shock has apparently lost pressure, and is sagging quite a bit. *annoyed* They're pressurized rear shocks, right? -=Russ=- Link to comment Share on other sites More sharing options...
Tcat55371 Posted February 10, 2005 Share Posted February 10, 2005 I run my wagon advanced and it makes a differance. I brought the car in for a clutch and tune up last summer and they set the timing to specs. I turned around withing 5 blocks and went back, borrowed a socket and advanced the distrib up a little. Much happier. (now if I ever see that kid on his bicycle that beat me off the light I'm goning to smoke him) Link to comment Share on other sites More sharing options...
subynut Posted February 11, 2005 Share Posted February 11, 2005 Tcat55371 said: (now if I ever see that kid on his bicycle that beat me off the light I'm goning to smoke him) Hehe...sounds like one of my sister's Suby. That thing is so slow granny could out walk it! Course, it died and got towed home today cause it refuses to start. This one's gonna be a tricky one to fix. I can see it now. Oh twell...off to brainstorming............... Link to comment Share on other sites More sharing options...
torxxx Posted February 11, 2005 Share Posted February 11, 2005 I rev my car to 5500 before I shift.... Every gear.. it doesnt complain. I do it everyday, all the time Link to comment Share on other sites More sharing options...
fud24682000 Posted February 12, 2005 Share Posted February 12, 2005 My '88 DL has A/C and an engine-driven fan besides the electric fan. Maybe removing that would free up some power if you have the same setup as mine. Ray Mac Link to comment Share on other sites More sharing options...
royboy159 Posted February 15, 2005 Share Posted February 15, 2005 My EA82 with SPFI does a little better than your carbed engine. But with good timing belts and hitting high revs without a second thought, I get to everywhere I'm goin' on time. Link to comment Share on other sites More sharing options...
Tin Soldier Posted February 15, 2005 Share Posted February 15, 2005 My old DL was the same way. I thought nothing of it until I got this loyale. It goes just fine. I drove it 300 miles at about 80 the whole way. Never had to shift outta 5thon the mountains either. My old dl eventually blew a head and never ran again. So I think I had something wrong. Link to comment Share on other sites More sharing options...
royboy159 Posted March 19, 2005 Share Posted March 19, 2005 Hey syonyk---How's the '88 DL running since the tune up and "european timing" change? Link to comment Share on other sites More sharing options...
Syonyk Posted March 19, 2005 Author Share Posted March 19, 2005 Oh. I don't know... I got a GL instead. It's not much better, but it has a tach so I feel better winding it out. The DL's timing was all the way advanced already, and it wasn't pinging, so I just left it. I had to replace the timing belts, but I haven't had it out much since then (selling it back to the guy I purchased it from - his brother-in-law needs a reliable car). The biggest things that have helped are just driver modification. Realizing that I can take on-ramps a lot faster than I had been, that I can just wind the engine up to 5k+ RPM before shifting, and that WOT for 30-40 seconds isn't a problem. That said, my GL is getting some more work on it soon - cold air intake, and a freed up exhaust system. Possibly a MSD6A to go with the Blaster 2 coil as well. -=Russ=- Link to comment Share on other sites More sharing options...
