MudisFun Posted February 11, 2005 Share Posted February 11, 2005 I just spent eight hours going to town on the latest subbie (84 DL wagon). At least two cans of cleaner, one hundred q-tips, three rolls of paper towels, two small wire brushes. The inside is soooo clean! I would have did some work on the engine and drive train but I'm poor right now. After all that work I started her up to go get some beer and the lights began too dim. She died after a few seconds of getting home. Damn, it's dark so I can't get it to the electrical. All I could really do is pull and replace the charging fuse and try to jump her with the 85 GL-10. Worked for a few minutes and that was it. Alternator, most likely... She has done good so far. Last night I was crusin' with my girl and a loud noise just started up. Got of the freeway almost knowing what it was. Whipped out the tool box searching for a tool to pry with. All that I found that was long enough was my 17 mm Snap-On combo wrench, no way in hell! So I removed the bar that holds the spare tire to tight up the drive belt. Long story short, I 'got some' later because I'm cool and my family station wagon is cool. But after all that explaining why I need a back-up soob just in case. Well I guess I was sort-of right? At least I got my beer. Link to comment Share on other sites More sharing options...
Wasteland Posted February 11, 2005 Share Posted February 11, 2005 Quote Long story short, I 'got some' later:brow: And Quote At least I got my beer. This just proves that Subarus make life better! Running or not. Link to comment Share on other sites More sharing options...
ballitch Posted February 11, 2005 Share Posted February 11, 2005 "professional grade" Link to comment Share on other sites More sharing options...
MudisFun Posted February 24, 2005 Author Share Posted February 24, 2005 Turns out it was not the Alternator . I checked the fuse and links but still there is no charging! I read something about a IR Regulator, may be some one can help explain this system to me? Link to comment Share on other sites More sharing options...
