Ross Posted February 12, 2005 Share Posted February 12, 2005 As i mentioned in another thread, i have just broken the ea81t's knock sensor. I can't get a replacement 'til at least monday and im wondering how to make it driveable. If the knock sensor is unplugged, does it put the computer or knock control unit into a 'limp home' mode? My other option is to have the broken knock sensor plugged in but off to the side somewhere. This way the knock control unit will think everything is normal and the engine is not knocking, right? Then the question arises, how much will the engine knock if i run it like this? I suppose the other option is to walk or bike to work, but it's not appealing as its raining! Any suggestions would be appreciated!! thanks. Link to comment Share on other sites More sharing options...
stngllhm Posted February 12, 2005 Share Posted February 12, 2005 my ea82t went into limp-mode with the knock senser removed ran for quite some time with out it. there was a loss of power but never heard any knock Link to comment Share on other sites More sharing options...
naru Posted February 12, 2005 Share Posted February 12, 2005 . If the knock sensor is unplugged, does it put the computer or knock control unit into a 'limp home' mode? Haven`t tested this to be 100% positive,but,the Knock control unit will retard timing 5 degrees w/sensor unplugged.No effect on ECU. My other option is to have the broken knock sensor plugged in but off to the side somewhere. This way the knock control unit will think everything is normal and the engine is not knocking, right? Yes Then the question arises, how much will the engine knock if i run it like this? Who knows? Buy a better grade of gas if you are worried. I would continue to drive if I was you. Link to comment Share on other sites More sharing options...
MilesFox Posted February 12, 2005 Share Posted February 12, 2005 knock the timing back a few degrees to be safe, since that is what the knock sensor does anyway Link to comment Share on other sites More sharing options...
