Rooba Doo Posted February 13, 2005 Share Posted February 13, 2005 Hey guys this is my first time using USMB and I have learned a great deal of stuff just browsing around. Anyway, just wondering if the heads on EA82 carb engines interchange with the heads on EA82 SMPI engines. Im not exactly sure what the problem is but my buddy says he is having trouble with one of his heads in his 4WD GL wagon (ea82 smpi) Now I have a 4WD GL wagon (ea82 carb) with an engine that runs. Just wondering if I could help him out with the parts I have. Link to comment Share on other sites More sharing options...
Snowman Posted February 13, 2005 Share Posted February 13, 2005 Yes, the heads will swap over just fine. Internally, the two engines are IDENTICAL except for the pistons and maybe the cams. (The SPFI motor has 9.5:1 compression compared to the carb's 8.7:1, which is caused by the piston variation.) Your carbed heads have a port in the exhaust manifold where air is inducted to help the cat burn excess fuel better. If you put the carbed heads on the SPFI motor, you have to block off those ports, as extra air in the exhaust will confuse the oxygen sensor. Link to comment Share on other sites More sharing options...
GLCraig Posted February 13, 2005 Share Posted February 13, 2005 Yes, the heads will swap over just fine. Internally, the two engines are IDENTICAL except for the pistons and maybe the cams. (The SPFI motor has 9.5:1 compression compared to the carb's 8.7:1, which is caused by the piston variation.) Your carbed heads have a port in the exhaust manifold where air is inducted to help the cat burn excess fuel better. If you put the carbed heads on the SPFI motor, you have to block off those ports, as extra air in the exhaust will confuse the oxygen sensor. Hey snowman FYI, the EA82 carb is 9.0:1 it's the EA81 that's 8.7:1. Oh there is another reason to plug the ports, if you don't you'll have a lot more noise under the hood, if you care about such things. Link to comment Share on other sites More sharing options...
Rooba Doo Posted February 13, 2005 Author Share Posted February 13, 2005 Yes, the heads will swap over just fine. Internally, the two engines are IDENTICAL except for the pistons and maybe the cams. (The SPFI motor has 9.5:1 compression compared to the carb's 8.7:1, which is caused by the piston variation.) Your carbed heads have a port in the exhaust manifold where air is inducted to help the cat burn excess fuel better. If you put the carbed heads on the SPFI motor, you have to block off those ports, as extra air in the exhaust will confuse the oxygen sensor. ------------------------------------------------------------------------------------------------------------------------------Thanks SNOWMAN I think im pretty sure what your talking about. A tube from the air pump going into the EX manifold?? but if not The 'PORT' you talk about on the (EA82) carbed heads........is it in the actual HEAD or on the Exhaust Manifold itself and if so could i get away with changing the manifold (using- spfi block, carbed heads, spfi manifolds- if they bolt up) or would this eliminate the hole for the O2 sensor OR if all else fails could i fill the holes (not O2 sensor hole ) with weld Sorry for the confusion Link to comment Share on other sites More sharing options...
MilesFox Posted February 13, 2005 Share Posted February 13, 2005 the holes in reference are on the side of the exhaust port, on carbs it runs up to the back of the head. on spfi this hole is not present, so you will have to block it. one cheap way i did such a thing was to cut the pipe ff and weld a bolt or spark plug in the inch length of pipe i left there is an egr port on the top of the passenger head, its the same between carb ans spfi so everything will fit the same if using the carb heads keep the spfi cam and tower to bolt on top of the head Link to comment Share on other sites More sharing options...
