scubasteveo45 Posted February 14, 2005 Share Posted February 14, 2005 the haynes manual says you have to remove the steering knuckle and axle as one piece and get them hydraulically seperated and re-pressed together. Ive heard differentely, its a 92 loyale, whats the real story? Link to comment Share on other sites More sharing options...
ShawnW Posted February 14, 2005 Share Posted February 14, 2005 Please do a search, this is a frequently discussed topic. Search Axle and user Edrach for about the best possible writeups. Link to comment Share on other sites More sharing options...
MorganM Posted February 14, 2005 Share Posted February 14, 2005 I've yet to find anything on my subaru that requires a hydrolic press Link to comment Share on other sites More sharing options...
MilesFox Posted February 14, 2005 Share Posted February 14, 2005 remove the roll pin on the inner end of the axle with a 3/16" drift punch. then pull the axle away from the tranny by eaither separating the ball joint with a fork, removing theball joint fom its pinch bolt, or by disconnecting the lower control arm. once that is done you can whack the end of the axle with a hammer and pound it out. be careful of the threads, iu use the round end of a ball peene hammer against the dimple on the end of the axle, and hit the ball peene with a 3 lb hammer to put the axle back on put it on the tranny end, slip the spindle end into the knickle and tap around the knuckel enough tull you can get the nut on, use the nut to draw the axle thru, tnen remove the nut, install the washers and then the nut Link to comment Share on other sites More sharing options...
scubasteveo45 Posted February 14, 2005 Author Share Posted February 14, 2005 thanks guys, and sorry about the re-posting, i'll look around before i ask next time Link to comment Share on other sites More sharing options...
subarubrat Posted February 14, 2005 Share Posted February 14, 2005 I use a 4x4 3 foot long piece of pine, one whack, no damaged threads and it is out. Link to comment Share on other sites More sharing options...
