MorganM Posted February 14, 2005 Share Posted February 14, 2005 I noticed a long time ago what one of my rear tires doesn't ride straight up and down anymore. It kicks out noticible faurther than the left one. I've seen on other EA82 wagons where BOTH rear tires kick way out; like a Baja buggy with lots of + camber. Why for does this happen? Havent quite figured it out myself Yes, I've crawled under there an looked WJM's bushing post got me thinking that maybe its the rear trailing arm bushings? Link to comment Share on other sites More sharing options...
idosubaru Posted February 14, 2005 Share Posted February 14, 2005 i believe you're right on with the bushings. you have some bad (or non existant) bushings back there most likely. at least one side is good, should be able to compare the two if it doesn't smack you in the face when you first take a look. Link to comment Share on other sites More sharing options...
Qman Posted February 14, 2005 Share Posted February 14, 2005 rear shocks adjusted up? Also check for rust in the rear or possibly bent parts. Especially if it is only one and not the other. Link to comment Share on other sites More sharing options...
archemitis Posted February 14, 2005 Share Posted February 14, 2005 hes got non ajdustable struts. i think what he wants to hear is that ist most likely a worn out rubber, and not a bent part. Link to comment Share on other sites More sharing options...
Qman Posted February 15, 2005 Share Posted February 15, 2005 Sorry. But I haven't ever seen a worn out trailing arm bushing on an EA82. I've seen some of your video's. A bent part is a strong possibility, Link to comment Share on other sites More sharing options...
archemitis Posted February 15, 2005 Share Posted February 15, 2005 buahahahahahahahaha, are you saying morganms rig is ghetto, or that he beats on it. Link to comment Share on other sites More sharing options...
mudduck Posted February 15, 2005 Share Posted February 15, 2005 It sounds to me like you might have tweeked somthing. Get underneath the car(if you have access to a lift even better)and compare how everthing looks from the right side and the left side. If any thing is tweeked it should be obvious, from your discription, it is quiet noticable just by loooking at the rear tires. Link to comment Share on other sites More sharing options...
Qman Posted February 15, 2005 Share Posted February 15, 2005 buahahahahahahahaha, are you saying morganms rig is ghetto, or that he beats on it. I didn't say it Link to comment Share on other sites More sharing options...
MilesFox Posted February 15, 2005 Share Posted February 15, 2005 is the steerig off center? a bent rear trailing arm will throw the steering wheel off. mine is bent and looks like camber Link to comment Share on other sites More sharing options...
torxxx Posted February 15, 2005 Share Posted February 15, 2005 I've hit my share of stuff with my wagon.. I'm going with bad bushing or blown struts. these control arms are strong as hell... There is a lot of rubber in the sooby rear end..... Link to comment Share on other sites More sharing options...
MorganM Posted February 15, 2005 Author Share Posted February 15, 2005 Doubt its anything bent. Dunno which video is in reference. I don't think I beat on it but offroading is pretty rough by nature. I'll have to go over the bushing closer. See what I can figure out I guess. Link to comment Share on other sites More sharing options...
MorganM Posted February 16, 2005 Author Share Posted February 16, 2005 Crawled all around the rear end lastnight. Bushings are in-tact. Nothing looks bent. I'm still Could it be one strut cartraige is worn out? Link to comment Share on other sites More sharing options...
bushbasher Posted February 16, 2005 Share Posted February 16, 2005 the 3 bolts that bolt on the outside portion of the trailing arm can pivot if you bounce off something too hard. The position of this determines camber. Likely these are out of whack. You gotta undo the bolts and reposition. The bolts are hell to get loose though, I had to use the torch to get the captive nuts red hot. You should be able to see that its rotated, because you'll see a silhouhette in the undercoating/rust that shows the old position. Hope this helps. The strut in the back isnt a strut really, it doesnt have anything to do with suspension geometry. Changes in ride height will change camber due to the design of the trailing arms. Sagged springs on the rear strut could cause this, but you'd notice because the car will look its draggin its rump roast. Link to comment Share on other sites More sharing options...
MorganM Posted February 16, 2005 Author Share Posted February 16, 2005 the 3 bolts that bolt on the outside portion of the trailing arm can pivot if you bounce off something too hard. The position of this determines camber. Likely these are out of whack. You gotta undo the bolts and reposition. The bolts are hell to get loose though, I had to use the torch to get the captive nuts red hot. You should be able to see that its rotated, because you'll see a silhouhette in the undercoating/rust that shows the old position. Hope this helps. The strut in the back isnt a strut really, it doesnt have anything to do with suspension geometry. Changes in ride height will change camber due to the design of the trailing arms. Sagged springs on the rear strut could cause this, but you'd notice because the car will look its draggin its rump roast. Excellent info; I'll check the outer arms and see if they have tweaked. Doesnt apear to my worthless eyes that one corner is sitting lower than the other; but that's nto saying much. I'll bust out the tape measure and see if one bumper corner is lower than another. Link to comment Share on other sites More sharing options...
